Author Topic: DT1 clutch from hell  (Read 11147 times)
Re: DT1 clutch from hell
« Reply #15 on: November 04, 2012, 10:35:21 pm »
Firko it works cause you change them in as a pair. When I'm home next ill foto one in a case
Thanks Freaky, that'll help quite a few of us looking for a better setup.
« Reply #16 on: November 05, 2012, 08:15:29 am »
Looking forward Freaky , can you still get the inner and outer from Yamaha ?
« Reply #17 on: November 05, 2012, 01:34:31 pm »
can be done with a bit of machining - mate here has done it on a 250B - much easier pull also.
« Reply #18 on: November 05, 2012, 02:19:59 pm »
the pair are like $19 on ebay.
« Reply #19 on: November 05, 2012, 02:21:58 pm »
i have only used it when the chain has taken out the covers  female helix, making the cover totally useless anyway. you fit the plastic side in the cover then you cut the old metal part off and drill 2 holes for litle bolts,
the rest of the set up works as per normal.
i wouldnt do it unless you fork a cover up or its a dt1 shit box cover dont go cutting up YZA covers to do it so you can save $50...... just saying   >:(
« Last Edit: November 05, 2012, 02:24:16 pm by Freakshow »
« Reply #20 on: November 05, 2012, 02:31:19 pm »
OK Freaky, I'm game....I'll try it on one of my DT1 covers. If it doesn't work I'll come and hunt you down ;D ;D.
Offline pancho
« Reply #21 on: November 05, 2012, 05:36:25 pm »
I think mine has the rd250 one. The pull is steal Nd the come with the female which us plastic. Wen you drop a chain it took out he old female side in the cover, so it was cut off Nd the new plastic coil bolts straight on. The new steel helix mates with it as there a pair and it works a treat.
You've outdone yourself this time Freaky ;D ;D ;D. I'm just heading down to the preschool to see if a toddler can decipher your post for me. ;D
[/quote I thort it waz mi
« Reply #22 on: November 06, 2012, 11:47:00 am »
im telling you its these forken new ipads and shit, there all over the shop, you cant get the work you want, it seems to know better.  grrrr
anyway let me find the cover and snap it first firko and ill see if it has a prefix ont he part to be sure.
hang in there i just have to remeber to do it.
Offline supermotomc
  • SWM ktm, dealer mechanic 1977-1995
« Reply #23 on: November 06, 2012, 12:10:08 pm »
Do you  still want the worm plastic and steel  with adjuster screw and lock nut  have one in my hand.... how do i ascertain its DT  1  had it in stock for years sure it what you want !
Offline supermotomc
« Reply #24 on: November 06, 2012, 12:12:55 pm »
just found your photo mine must be ct 1 i think sorry
Offline Andrew L
« Reply #25 on: November 20, 2012, 08:57:10 pm »
Just emailed a guy on ebay selling his rt1 which he has fitted a gsxr clutch actuator heres what he had to say,
"No problem suzuki p/no 2320031300 they might put it on back order but they will supply it will require a small amount of modification relocating holes in new part to match your sprocket cover [ use only 4mm bolts] and i think i inserted a ballbearing into the end of it and shortened the push rod to suit this will definatly give you a 1 or2 finger clutch depending on your cable and levers the long mcs copy of yamaha ones work great this actuator is all steel no nylon"
could be the go, im going to order one and give it a try as mine still works but looks like its split in half looking through the hole not game to pull it out to find out might no go back together if I do. Photo in the ebay finds section under black betty rt1
« Last Edit: November 20, 2012, 08:59:23 pm by mavman4200p »
« Reply #26 on: November 20, 2012, 10:27:08 pm »
I'll check out the Suzy part or you could try the Yamaha RD350 part it has 4 splines
