Author Topic: Yamaha YZB info required  (Read 19708 times)
Re: Yamaha YZB info required
« Reply #60 on: November 26, 2012, 08:14:23 pm »
Crank seal should be the same as the Dt1 etc same across the board, I just buy them in a pack think you get the six seals for $50
Be careful with some of those NOS seals those card packs that come up on eBay. I've bought a couple that were so old and hard I wouldn't use them, other times they've been just fine. I guess it's a pig in a poke with this old stuff.
« Reply #61 on: November 26, 2012, 08:53:34 pm »
« Reply #62 on: November 26, 2012, 08:56:26 pm »
There all new the one I have been getting are remakes at worst ten year old stock others on the clear cards are new rubber remakes .  I have snapped the one above that gives the sizes and oem part numbers printed on the card for your reference
« Reply #63 on: November 26, 2012, 09:56:11 pm »
thanks Freaky
« Reply #64 on: November 26, 2012, 11:48:34 pm »
mrs superdeals has them on US Evilbay all the time about $35 us
Offline OverTheHill
« Reply #65 on: November 27, 2012, 09:12:56 am »
Saw a DT/RT motor a while back where the guy had--had the mag side case sleeved to reduce the outer diameter so as to be able to use a readily available seal, not sure if he'd done the right side also but probably. Suppose that doesn't help sort the clutch pushrod seal but maybe the same could apply if a common seal is found.
« Reply #66 on: November 27, 2012, 10:00:52 am »
thanks Guys - Iain - have stumbled on mrs superdeals late last night - see how I go.
« Reply #67 on: November 27, 2012, 01:48:02 pm »
OTH i have a stack of clutch push rod seals if you need them ?
« Last Edit: November 30, 2012, 04:46:18 pm by Freakshow »
Offline OverTheHill
« Reply #68 on: November 28, 2012, 09:35:50 am »
Thanks Freakshow, i'll get in touch sometime. All the best.
« Reply #70 on: December 06, 2012, 10:12:22 am »
thanks iain - he is on vacation so cannot buy currently.
regards
« Reply #71 on: December 06, 2012, 02:29:34 pm »
yep thats the guy i have been gettign them from, think his name si andrew.  only issue with them is the postage seems to cost more form canadia and also take like a month. seriously they still use boat mail. i though he had lost mine, 2 month later they turned up....... so dont panic if they take a while. but yes this guy is great service and the seals are good too have them in allmy bikes and never had a DNF or failure
« Reply #72 on: February 14, 2013, 11:58:51 am »
Davey - how are the clutch covers progressing?
Rossco
