Author Topic: Yamaha YZB info required  (Read 19707 times)
Re: Yamaha YZB info required
« Reply #30 on: November 06, 2012, 09:53:20 pm »
Still waiting big boy.....cant push him to hard......its getting closer by the day.
« Reply #31 on: November 07, 2012, 09:40:55 am »
fair enough  ;D
« Reply #32 on: November 12, 2012, 03:31:32 pm »
sorry for the delay here goes.
didnt have an allen key with me to take the cover off, but is a 4 helix with a metal male and a plastic female. just bolted up in the same holes with 2x 4/5mm bolts and nuts where the little coverused to mount into.
also think the female outside was cut down a little as it didnt need all the thread as it stuck out.
« Last Edit: November 12, 2012, 03:45:19 pm by Freakshow »
« Reply #33 on: November 12, 2012, 03:46:37 pm »
ok... insert the work butchered off the excess plastic ;)
« Reply #34 on: November 12, 2012, 04:00:22 pm »
« Reply #35 on: November 16, 2012, 09:47:54 am »
is the pipe on the MXB also a 2 piece unit like the YZB?  Does the lower section straight out of the barrell fit the YZ if so?
« Reply #36 on: November 16, 2012, 11:32:55 am »
The peice wont fit on the barrell Ross, the rest is pretty much the same, looked at the proto type for the clutch actuator this morning....looks good, he's making the helix for the cover aswell as a bolt in and it will run a XS650 male push lever with the 1T3 p/n....cheap as chips and with the longer arm should have a clutch pull light as a feather, I'm hoping to have the first one to try this afternoon. It's a head fark but will be the ducks guts when finished.
« Reply #37 on: November 16, 2012, 01:04:29 pm »
firstly - bugga!!
Secondly - good news John.  Does the XS push lever fit straight on or need mods?  Or were the mods to the cover side which you are incorporating anyway?
Have my DG swingarm in the queue - giving the beastie a birthday whilst it is so long between rides.  Also going to incoporate a more modern enclosed chain guide with the swingarm so won't have any dramas there also - make the most of the opportunity.
« Reply #38 on: November 16, 2012, 01:59:28 pm »
I wont know if I need to shorten the helix untill we do a dummy run......but it wont look like Freaky's shitfight. ;D
« Reply #39 on: November 16, 2012, 02:32:50 pm »
it works..... and you guys had to start somewhere.
« Reply #40 on: November 16, 2012, 02:34:06 pm »
i think you have to just change the inzee pipe fitting to the outzee fitting at the spigot.
« Reply #41 on: November 16, 2012, 03:08:45 pm »
I'll translate that for you Ross    "The YZB pipe spigot goes over the outside of the flange, whereas the MXB spigot goes on the inside"....it's Friday and it's hot.....dont know what Freaky's excuse is though....South Australian? ;D
« Reply #42 on: November 16, 2012, 03:42:45 pm »
but we still love him  ::)
« Reply #43 on: November 16, 2012, 05:04:34 pm »
Inzee outzee like a belly button, prity simple explanation I thought
« Reply #44 on: November 19, 2012, 07:38:20 pm »
How's this
