Author Topic: Yamaha YZB info required  (Read 19704 times)
Re: Yamaha YZB info required
« Reply #45 on: November 19, 2012, 10:25:49 pm »
Thats good but the one to use has a longer arm on it so the clutch pull will be 1 finger (hopefully)....we are making the plastic screw part and that will come with it. If you have that one, how long is the male helix? Cheers.
« Reply #46 on: November 19, 2012, 11:57:00 pm »
I havn't bought it Davey (yet ) at $30 is it worth the convert required ?
« Reply #47 on: November 20, 2012, 12:11:37 am »
Hopefully toomorow Ill have the first one....theres lots of little hiccups with the cover. The long one is about $30 NOS on ebay so dont panic.
« Reply #48 on: November 22, 2012, 05:57:28 pm »
This is the first prototype in plastic, the yellow on the botton of the cover wiil have that section removed, its too close to the gear lever. The real ones will be made from 6061 alloy. The clutch feel even with the plastic flexing is way more positive and the lever returns very snappy like a modern bike. There will be a cover for the adjuster. The clutch pull is way lighter, I dont know what they where thinking when they made the originals. Tell me your thoughts fellas.
Offline Tahitian_Red
  • Mugen ME480
« Reply #49 on: November 22, 2012, 06:27:52 pm »
Looks great!!!  ;D
The "Factory Novice"
California, USA
Offline gt96
« Reply #50 on: November 22, 2012, 06:56:50 pm »
Excellent! Assume the top is open so there is no interference with the chain at full travel?
When and how much?
« Reply #51 on: November 22, 2012, 09:35:37 pm »
Wow it looks great . put me down for three . Iain
« Reply #52 on: November 22, 2012, 09:44:34 pm »
Fantastic, even better than I'd imagined. Put me down for at least two, possibly four.
« Reply #53 on: November 22, 2012, 09:52:28 pm »
That reversed fitting looks familiar..... ian it works.
If your taking the bottom section out then take the right end section out otherwise it's going to look unbalanced.
Can you incorporate a threaded section or ability to take one for the lover cable outer.
Can you creat a case saver or derailer in the top section so the chain can't Spool up in to the clutch rod, even if you make it alloy backed onto the mag so we can weld a plate in there and put a hole in the flat for the clutch rod to pass through.
The shape of the 2mx is the perfect design to follow as the shape cover everything and room for the gear lever.  D you have one or seen one ? Suss one out
« Last Edit: November 22, 2012, 09:54:37 pm by Freakshow »
« Reply #54 on: November 25, 2012, 10:45:23 pm »
Davey - looks good - big isn't it  ;D
One question - since the sprocket cover is so important - is it OK with such a large open area?
Also - Yam Gurus - does anyone have a spare LH crank seal they would be prepared to sell - I am struggling to find one.  Have a RH on the way though?
Part number 93103-30044-00.
« Reply #55 on: November 25, 2012, 10:47:53 pm »
I reckon next years Nats will see a dozen of these on bikes ;D
« Reply #56 on: November 26, 2012, 06:40:39 pm »
Crank seal should be the same as the Dt1 etc same across the board, I just buy them in a pack think you get the six seals for $50
« Reply #57 on: November 26, 2012, 06:44:30 pm »
Your probably right the open areas at the back would get a lot of shit stuck in there like sticks and stuff.  I'd be inclined to close those down in size and shape
« Reply #58 on: November 26, 2012, 06:58:34 pm »
but where from freaky - I use the part number to search which is across a range of bikes and can't find this one?  So if you know where you can buy a pack please let me know?
« Reply #59 on: November 26, 2012, 07:40:00 pm »
No don't search the single part search Dt1 seals they sell them on a carded pack, cost about fifty bucks by the time they get here.  If you get stuck I have some paks here
