Author Topic: Backfire through exhaust  (Read 2880 times)
Offline Rod Rocket
« on: September 20, 2012, 02:04:21 pm »
My xl 500s Honda is backfireing through the exhaust on over run,backed off down hill,under power pulls like a train. The motor has a 95mm wiesco sleeve and hi-comp piston making it 600cc the carb is standard jets and needle setting, air filter cleaned each ride. I lost an exhaust stud from the head and gasket and split ring subsequently were also lost have replaced all part's hoping it may have been a problem for a while but made no difference. Any clue's.
Regards Rod. ???
I,m not very smart but I can lift heavy objects.(well I used to be able to.)
Re: Backfire through exhaust
« Reply #1 on: September 20, 2012, 02:13:06 pm »
your at 600cc but on standard 500cc  jets and float heights....... try changing the pilot jet, out of curiosity.
« Last Edit: September 20, 2012, 02:14:43 pm by Freakshow »
« Reply #2 on: September 20, 2012, 02:20:48 pm »
It's too lean.. Go to a bigger pilot jet
Offline EML
« Reply #3 on: September 20, 2012, 02:27:48 pm »
Could still be sucking air on over run, recheck around where the header pipe joins the head and then again if the is a join half way down the exhaust.
Offline bazza
« Reply #4 on: September 20, 2012, 02:45:38 pm »
LEAN
Offline EML
« Reply #5 on: September 20, 2012, 02:58:24 pm »
Listen again. It could be lean because extra air is getting into the hot system and after-burning the un-burnt fuel. Check your plugs. Ours are always black and sooty-so it's not too lean-at the chamber.
Offline pancho
« Reply #6 on: September 20, 2012, 04:37:29 pm »
 Almost always air leak into exhaust.
 Can be lean on idle [pilot jet.]
 Can be crook plug/resistor/lead.
 Can be tiny air leak to inlet behind carby under max. vacuum (throttle closed)
« Last Edit: September 20, 2012, 04:45:33 pm by pancho »
« Reply #7 on: September 20, 2012, 06:04:37 pm »
If its recently started backfiring its probably the exhaust header leaking.. If its always done it since fitting big bore kit it's the jetting(pilot). Simple ;)
Offline Rod Rocket
« Reply #8 on: September 20, 2012, 07:34:06 pm »
Thanks for the reply's,
I have replaced the exhaust gasket's with the replaced stud in the head, I filed the face of the header pipe's to make sure they were square and on the same plane so they would seat well to the gasket's. Tightened them to firm ran the bike for a while then re-tightened them the join half way along the pipe also re sealed and tight. The bike has been backfiring for a while but has been getting worse of late. Sound's like I need to re-check tommorow.
Regards Rod.  ;D
