Clubroom
Tech Talk
Backfire through exhaust
Topic: Backfire through exhaust (Read 2874 times)
Rod Rocket
Novice
September 20, 2012, 02:04:21 pm »
My xl 500s Honda is backfireing through the exhaust on over run,backed off down hill,under power pulls like a train. The motor has a 95mm wiesco sleeve and hi-comp piston making it 600cc the carb is standard jets and needle setting, air filter cleaned each ride. I lost an exhaust stud from the head and gasket and split ring subsequently were also lost have replaced all part's hoping it may have been a problem for a while but made no difference. Any clue's.
Regards Rod.
I,m not very smart but I can lift heavy objects.(well I used to be able to.)
Freakshow
Superstar
Adelaide, SA - looking for a "YZA" tank
Re: Backfire through exhaust
September 20, 2012, 02:13:06 pm »
your at 600cc but on standard 500cc jets and float heights....... try changing the pilot jet, out of curiosity.
Last Edit: September 20, 2012, 02:14:43 pm by Freakshow
74 Yamaha flattracker's
70 Jawa 2 valve speedway's
For sale - PRE 75 Yamaha MX stuff, frame, motors and parts also some YAM DT1,2,A and Suzi TS bikes and stuff
JohnnyO
Qld
September 20, 2012, 02:20:48 pm »
It's too lean.. Go to a bigger pilot jet
EML
Ride the World before it Rides You
September 20, 2012, 02:27:48 pm »
Could still be sucking air on over run, recheck around where the header pipe joins the head and then again if the is a join half way down the exhaust.
bazza
Reply #4 on:
September 20, 2012, 02:45:38 pm »
LEAN
Once you go black you will never go back - allblacks
Embrace patina
EML
Reply #5 on:
September 20, 2012, 02:58:24 pm »
Listen again. It could be lean because extra air is getting into the hot system and after-burning the un-burnt fuel. Check your plugs. Ours are always black and sooty-so it's not too lean-at the chamber.
pancho
Reply #6 on:
September 20, 2012, 04:37:29 pm »
Almost always air leak into exhaust.
Can be lean on idle [pilot jet.]
Can be crook plug/resistor/lead.
Can be tiny air leak to inlet behind carby under max. vacuum (throttle closed)
Last Edit: September 20, 2012, 04:45:33 pm by pancho
JohnnyO
Qld
Reply #7 on:
September 20, 2012, 06:04:37 pm »
If its recently started backfiring its probably the exhaust header leaking.. If its always done it since fitting big bore kit it's the jetting(pilot). Simple
Rod Rocket
Novice
Reply #8 on:
September 20, 2012, 07:34:06 pm »
Thanks for the reply's,
I have replaced the exhaust gasket's with the replaced stud in the head, I filed the face of the header pipe's to make sure they were square and on the same plane so they would seat well to the gasket's. Tightened them to firm ran the bike for a while then re-tightened them the join half way along the pipe also re sealed and tight. The bike has been backfiring for a while but has been getting worse of late. Sound's like I need to re-check tommorow.
Regards Rod.
Clubroom
Tech Talk
