Author Topic: Want To Turn TM 125 IN CR eater  (Read 18824 times)
Offline Dono113
« on: August 08, 2012, 02:07:27 pm »
Read a thread which was dated awhile back on TM125 go fast tips, interested in making my 73 TM125 into a CR eater or close to, have a spare motor in case things go south :o, but I'm tired of chasing hondas any help would be excellent. I know youse have spoke of porting, changing CDI etc. just need to be pointed in right direction.
1983 CR125R
2003 CRF450R
CB750K1
2005 YZ85
1969 TS 250
Offline 09.0
Re: Want To Turn TM 125 IN CR eater
« Reply #1 on: August 08, 2012, 02:21:15 pm »
Easiest way is to undo the filler cap and slide a cr125 under it! Sorry not helpful. I'm just a smart ass!
Methanol is the biggest increase in hp bar none if you are happy to play with that stuff. I even hate the idea of the high maintenance assossiated with it.
« Reply #2 on: August 08, 2012, 02:26:09 pm »
The only guy in Oz I saw get a TM125 going was Terry Bryant (R.I.P.) from Bryant Suzuki in Frankston, he built the bike for Jeff Beattie; twas a rocketship.  I wonder if Craig Jordon (Jordo) who was the apprentice then picked anything up?
Maybe slap in an RM125S engine?
I think those single-channel transfer ports were the limiting factor in those engines?
TM BILL
« Reply #3 on: August 08, 2012, 02:41:04 pm »
Dont think it will happen all things being equal, i tried everything short of bringing in a priest but they are limited  . As Brad said methanol will give a gain but lots of dramas  ::) RM 125S motor great but not pre 75 legal  ::) Lozza can probably port a TS cylinder for you ( they are a better starting point ) but if the other riders are of similar or better riding ability its a lost cause . 5 speed box is also limiting Crs are 6 speed , the fast Crs are on methanol and i found that on uphills they just run away . Davey crocket (Joan ) has built a fast reliable YZ 125A but its still a 5 speed  ??? Vandys MX 125 is a good fast pre 75 125 but still a 5 speed .
Honestly learn to corner real fast and hope the tracks dont have too many long straights or uphills and you may be in with a shot . Otherwise buy an Elsinore or a KX 125  ;D probably the only real contender to the Elsinore with stock motor and soooooooo easy to ride , sweet linear power and 6 speeds and they dont load up like an Elsinore  ;)  , you just have to work the suspension .  Rob Tumes from SA has had great succsess  on his KX at the nats in years gone by .
Tm is a great bike but a title contender  ??? not unless your name is Akira Watanabe  ;D
« Last Edit: August 08, 2012, 02:42:48 pm by TM bill »
Offline huskibul
« Reply #4 on: August 08, 2012, 02:47:01 pm »
   Or jens olsen ! back in the early 70's jens used to regularly beat top  A graders on elsinores on  TM's ,if you can untap his secrets your half way there  :D
« Reply #5 on: August 08, 2012, 03:18:53 pm »
this is what tm bill is talking about
last sunday pre90 125 dirt track 1st place brett chipperfield 1974 cr125.yes he is an a grader and yes it is his bike from new.
example 2
terry sayer(i think) 1977 cr125 runs on methenol reg 1st or 2nd evo 250 dirt track
jim
« Reply #6 on: August 08, 2012, 04:33:14 pm »
There are a few things to consider, the 5 sp is OK you just have to build the engine around it. Engine has limitations but there is nothing stopping you getting close to the CR in mx, dirt track is a bit different.
A TS cylinder is better starting point than a TM cylinder
TM ignition is woeful best swapped for a YZ80/100.
Use CR pistons.
In mx you will have a small window to get on top of CR's from mid corner to exit, if you can get good drive there your in with a chance.
No need for KX's Bill you can do it with a humble KH 125. ;)
PM Brentj and he'll fill you in on some details.
« Reply #7 on: August 08, 2012, 04:34:07 pm »
What do you want to do,club days or win titles.?
A search on this forum is a great knowledge base.TM's can & do win titles.  :)
The little TM's may not have been the hottest ticket on the planet at the time but they were and still are one of the most reliable.
Offline bazza
« Reply #8 on: August 08, 2012, 04:57:54 pm »
put a TM tank on a CR
TM BILL
« Reply #9 on: August 08, 2012, 05:15:59 pm »
A search on this forum is a great knowledge base.TM's can & do win titles.  :)[/font]
Enlighten me do  ??? when did a TM 125 win a vintage title ?? Doc got a very well earned 3rd at the Coffs titles  :) 250s and 400s have won titles for sure although i believe in those cases it has been 90% rider 5% bike and 5% good fortune  ;)
« Last Edit: August 08, 2012, 05:20:52 pm by TM bill »
TM BILL
« Reply #10 on: August 08, 2012, 05:17:44 pm »
Use CR pistons.
Do you fit knobblys to the KH Lozza  ??? and do you run the std KH suspension  ;D
« Reply #11 on: August 08, 2012, 05:26:58 pm »
TM's can & do win titles.[/[/color]font]
Enlighten me do  ???
I didnt mention capacity !  :)
The question was pretty open..How longs a piece of string and what money/time has he got to spend   :P
« Reply #12 on: August 08, 2012, 05:41:08 pm »
Ive herd of guys moving the barrel studs to fit another transfer port? Dave Tanner has a sweet one that I love the look of.
The only thing better than a Honda is an Honda engine in a KTM frame  ;)
« Last Edit: August 08, 2012, 05:43:59 pm by Slakewell »
Offline Graeme M
  • Administrator
  • Canberra, Australia
« Reply #13 on: August 08, 2012, 08:33:32 pm »
What they all said...   ;D
Curly3
« Reply #14 on: August 08, 2012, 09:07:29 pm »
I'm interested, as a kid I dreamed of having a TM125 and one day I will.
Carefull what you say Alison, everything has to be backed up with fact, ;)
