Author Topic: Honda TL250 condensor  (Read 9562 times)
Offline bazza
« on: August 03, 2012, 08:36:13 pm »
Any contacts for new condensor??
Embrace patina
Offline matcho mick
    • Moto Tumbi
Re: Honda TL250 condensor
« Reply #1 on: August 03, 2012, 11:59:52 pm »
Bosch holden 186 ;), :P
Offline David Lahey
« Reply #2 on: August 04, 2012, 10:30:12 am »
any condenser intended for points ignition will work. I usually browse at the auto electrical shop to find one that is easy to mount and has a long enough cable. Try to avoid buying an old one (ie NOS genuine - made in 1975) because they have a finite life
previous pseudonym feetupfun
Montynut
« Reply #3 on: September 01, 2012, 07:07:34 pm »
Mount the condenser at the coil under the tank instead of at the points. It is cooler, easier to change and you don't have to find one the samne size. It also gives a little more room at the points for adjustment
Offline matcho mick
    • Moto Tumbi
« Reply #4 on: September 01, 2012, 09:40:20 pm »
duh,where do you think the points are scrivo?,thinking thinking,oh look the condensors on the coil under the tank,bewdy ::), :P
Offline Noel
« Reply #5 on: September 01, 2012, 10:03:15 pm »
go easy Mick,
Scrivo is not enlightened to Honda's and four strokes yet ;D
Noel
Montynut
« Reply #6 on: September 02, 2012, 12:43:34 am »
Geezus Mick  :'( last time I dive in. OK forgot the bloody 'work of the devil' 4st hondas already had the condensers at the coil. Should have remembered from my SL100 and XL250 days from 1972-74. OK mount the bloody thing where you want ;D ;D
Offline bazza
« Reply #7 on: September 02, 2012, 08:45:51 am »
put the holden 186 condensor on yesterday and shes going well
Embrace patina
Offline paco
« Reply #8 on: September 02, 2012, 10:11:39 am »
Burnt moving point;Condenser to weak.Burnt fixed point;Condenser to strong.
what ! Who me ? Nah
Offline pancho
« Reply #9 on: September 02, 2012, 11:07:59 am »
 What you mean is-
 A PIT on the POSITIVE means to much caPACity!
  OR-
Not eNUFF caPACity makes a NOLE in the NEGative!
cheers.
Offline paco
« Reply #10 on: September 02, 2012, 02:15:11 pm »
Yes thats what I meant:Although I couldn't put it as well as you did Pancho.
what ! Who me ? Nah
Offline huskibul
« Reply #11 on: September 02, 2012, 02:34:23 pm »
   What i'd like to know is what are you bloke's on and will you be taking any to CD   ;D
Offline matcho mick
    • Moto Tumbi
« Reply #12 on: September 02, 2012, 08:21:00 pm »
yep,& if i run out go see KTM555 ;D, :P
