Author Topic: MT 250 Barrel on a CR  (Read 2696 times)
Offline PCMAX
« on: July 22, 2012, 06:40:47 pm »
Anyone know if the MT barrel drops straight on to the CR? What's the difference in power spread?
Offline Noel
Re: MT 250 Barrel on a CR
« Reply #1 on: July 22, 2012, 06:52:28 pm »
Not your 75/76 CR, ehaust port on opposite side
will fit 73 /74 but you need the head as well, and probably the piston,
a very detuned   compared to CR
Noel
Offline PCMAX
« Reply #2 on: July 22, 2012, 07:17:21 pm »
Ahhh thanks Noel, I just went back and had a look at the pics of the one I was looking at on Ebay (http://www.ebay.com.au/itm/260974336819?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649) and you are quite correct exhaust on the wrong side. The upside down pics threw me a bit though I was almost convinced it would fit.
I can go tell the wife I just saved another $97.50 on VMX parts then ;D ;D ;D
« Reply #3 on: July 22, 2012, 11:42:08 pm »
Modified MT cylinder is the best thing you can do for a CR.
« Reply #4 on: July 23, 2012, 07:33:52 am »
lozza
they dont fit 75/76 crs only 73/74 i have both cr engines
Offline PCMAX
« Reply #7 on: July 23, 2012, 11:46:29 pm »
Later has short base studs early has long through studs, early has exhaust duct on the right later has outlet on the left. I have a 75 model here ATM I'll see how hard it would be to fit the early cylinder and use long studs/bolts. Early cylinder looks like it has more potential especialy if you convert to a reed.
« Reply #8 on: July 24, 2012, 06:17:30 am »
i domt think so it was for sale if you needed one.i think matcho mick has a nos 75/76 barrel for sale
jim
