Author Topic: Removing carbon build up  (Read 1892 times)
« on: June 27, 2012, 08:36:05 pm »
Further the IT thread, is there anything that can be used to disolve the carbon from the inside of the pipe, ie a liquid to pour into the pipe and leave overnight ?
Offline worms
Re: Removing carbon build up
« Reply #1 on: June 27, 2012, 08:56:21 pm »
Try Molasses Brenden! pour in, leave over night and rinse, then next would be Phospheric acid or oxcalic acid, both are rust convertors,
Cheers Worms
Offline Hardo
« Reply #2 on: June 27, 2012, 08:56:59 pm »
Media blast it, or burn it out with heat (ie oxy torch) ... but with the burn method, use ventilation as it will SMOKE the workshop out !!!    :)
Offline Moto
« Reply #3 on: June 28, 2012, 08:45:07 pm »
I have used Caustic soda and it works well.Mix it as per instructions.(well, maybe a bit stronger)
Seal one end of the pipe,pour it in and fill the pipe and leave it standing for a few days.
Repeat as necessary.
Offline Nobby25
  • Could possibly fit other models?
« Reply #4 on: June 28, 2012, 08:47:50 pm »
Pay the Tax?  ;D
TM125L RM250N TC125L RL250M PE175T RM80C RMX250T ATC70 YZ80B?
Offline AjayVMX
    • VMX Magazine
« Reply #5 on: June 28, 2012, 08:58:57 pm »
Yep the Carbon Tax should fix that....  ;D
