Clubroom
Tech Talk
Removing carbon build up
Topic: Removing carbon build up (Read 2041 times)
evo550
June 27, 2012, 08:36:05 pm »
Further the IT thread, is there anything that can be used to disolve the carbon from the inside of the pipe, ie a liquid to pour into the pipe and leave overnight ?
worms
Re: Removing carbon build up
June 27, 2012, 08:56:21 pm »
Try Molasses Brenden! pour in, leave over night and rinse, then next would be Phospheric acid or oxcalic acid, both are rust convertors,
Cheers Worms
Hardo
June 27, 2012, 08:56:59 pm »
Media blast it, or burn it out with heat (ie oxy torch) ... but with the burn method, use ventilation as it will SMOKE the workshop out !!!
Moto
A-Grade
June 28, 2012, 08:45:07 pm »
I have used Caustic soda and it works well.Mix it as per instructions.(well, maybe a bit stronger)
Seal one end of the pipe,pour it in and fill the pipe and leave it standing for a few days.
Repeat as necessary.
Nobby25
B-Grade
Could possibly fit other models?
Reply #4 on:
June 28, 2012, 08:47:50 pm »
Pay the Tax?
TM125L RM250N TC125L RL250M PE175T RM80C RMX250T ATC70 YZ80B?
AjayVMX
Reply #5 on:
June 28, 2012, 08:58:57 pm »
Yep the Carbon Tax should fix that....
Clubroom
Tech Talk
