Author Topic: RM125A v RM125B pistons?  (Read 7324 times)
« on: June 20, 2012, 12:21:29 am »
Would anyone have 125A and 125B pistons laying around for comparison?  I know the A has a 2mm larger bore than the B, what I was interested to know is, could a 125B be bored out after the 2mm (80 thou) Wiseco with a 1st over 125A piston?
It looks like there is enough thickness in the liner to not alter port exit or timing.
Deck heights, ring stops, pin diameter's, skirt lengths etc?
Re: RM125A v RM125B pistons?
« Reply #1 on: June 20, 2012, 01:02:26 am »
rm125a has 56 bore by 50 stoke same as the rms125 but the rm125a has a 16mm piston pin 2mm bigger in diametter than the rms125 and the rm125b which is 14mm while the rm125b has a 54mm bore and stroke sooo wheather the rms125 piston would suit dont know but youd have to do alot of checking of things like pin hieghts/skirt clearence/port timing etc
« Reply #2 on: June 20, 2012, 10:57:28 am »
Cool, thanks.  I might check out a 125S piston?
Offline Doc
« Reply #3 on: June 20, 2012, 01:17:58 pm »
The ring locating pin maybe an issue so double check the rings don't hang up in any ports. I have heard of people using TS125 std piston but the lower ring had to be removed because of this problem.
« Reply #4 on: June 20, 2012, 01:25:53 pm »
Thanks Doc, I had my concerns about port placement.
Offline EML
« Reply #5 on: June 20, 2012, 01:35:41 pm »
You could also try other makes. I remember my Honda 125 needed a piston and they found a Suzuki one to do the job as none were available from Honda-around about that time i.e RM's' TS CR MT 125 all pretty much similar.
Maybe check with Wiseco they would know. Try Serco.
« Reply #6 on: June 20, 2012, 02:34:14 pm »
Good idea, I remember wiseco use to have a chart with dimensions of all pistons that they made, anyone know of something similar around now?
Offline asasin
« Reply #7 on: June 20, 2012, 03:32:30 pm »
TS 125 piston works ok , just machine the bottom as they are about 2mm longer. and the B barrel will go all the way out to 58 mm if needed.
If in doubt ,WIND IT OUT
« Reply #8 on: June 20, 2012, 04:28:26 pm »
Awesome!  Which model TS125?  Using one or two rings?
Offline Suzukal
« Reply #9 on: June 20, 2012, 05:15:57 pm »
The next problem would be, you'd have to run it in the 250 class as it's outside the 5% limit for the 125 class.
Wiseco don't make TM/TS125 pistons anymore but you can use their Honda 74 CR125 pistons.
You just need to trim a couple of mm off the skirt.
« Reply #10 on: June 20, 2012, 05:23:25 pm »
That's cool, I'm not racing it anyway, I've got a few barrels if I was going to run it in a 125 class.  I'm thinking of riding it in modern lites class which is up to 250 2 & 4 stroke.
« Reply #11 on: June 20, 2012, 05:28:22 pm »
if thats the case why not make a cloe ratio pe175 with the rm125 box and rotor as the 175 will take 185 pistons as well,but if your sticking to the 125 ive got a new ts125 early std piston/rings and pin pm me if you want to know more
« Reply #12 on: June 20, 2012, 06:01:34 pm »
I don't have a PE engine laying around, and I'm not going to buy one  :-)
I'll PM you about the piston, thanks.
« Reply #13 on: June 20, 2012, 06:04:25 pm »
It seems all the current 125's (Yam, Husky, KTM) are running 144 kits these days; no problem running in the up-to-250 class.  I have a 2010 YZ250 2-stroke but it'd be a buzz to smoke some kids with the 'vintage' bike lol.
« Reply #14 on: June 20, 2012, 07:47:34 pm »
S/e pin size is different for A & B, so unless you run an A rod in your B you won't be able to run an S or A piston. Cr125M pistons can be used in S & A with small mods. Gives a compression boost as well.
