Author Topic: RM125A v RM125B pistons?  (Read 7187 times)
Offline Doc
Re: RM125A v RM125B pistons?
« Reply #15 on: June 20, 2012, 07:57:24 pm »
K..the 125S use 14mm s/e pin, only the RM125A used the 16mm ;)
albrid-3
« Reply #16 on: June 20, 2012, 09:19:32 pm »
Would there be anybody interested in a RM125A complete bike in mint condition
« Reply #17 on: June 20, 2012, 11:15:04 pm »
So I'm looking at a TS125 piston or an RM125S piston, I'd expect the RM piston to be more acommodating for extra boost ports.
« Reply #18 on: June 21, 2012, 01:57:21 am »
rm125s pistons and rings are like hens teeth to buy but rm125m are still plentyfull last time i went checking ebay for parts for them and the m is a 6 transfer port cylinder like the s is sooo the pins in the ring lands might be in the right position.
« Reply #19 on: June 21, 2012, 08:28:03 pm »
John the best thing you could do for that type of racing is increase the stroke(easy peasy) run a longer rod with the full reed motor. Rod swaps are not easy due to the 19mm crank pin.
« Reply #20 on: June 21, 2012, 08:52:34 pm »
Which motor are you thinking of? They didn't go to a full reed until the '82 watercooled.
« Reply #21 on: June 22, 2012, 09:49:19 pm »
Was thinking of the water cooled engine.
