Author Topic: CR125M jetting  (Read 2265 times)
Offline suzuki27
CR125M jetting
« on: May 14, 2012, 04:28:54 pm »
Can anyone help with jetting specs for a 30-32mm round slide Mikuni to be put on a 75 CR125? Cheers.
Offline suzuki27
Re: CR125M jetting
« Reply #1 on: May 15, 2012, 06:58:35 pm »
Was that a rude question or is it tightly held info?
Offline 09.0
Re: CR125M jetting
« Reply #2 on: May 16, 2012, 06:52:56 pm »
I think the latter.
I have a pre jetted 32 that if you are patient I will get back to you with the info. It hasn't been put on the bike yet.
Offline suzuki27
Re: CR125M jetting
« Reply #3 on: May 16, 2012, 08:38:21 pm »
Sounds good 090.
Re: CR125M jetting
« Reply #4 on: May 17, 2012, 12:24:28 pm »
How about using the 'search' function? Because after an exhaustive 15 second search I found the question had been covered at least 3 times prior. Someone was even kind enough to post this link
http://www.braigasen.com/Mikuni_jetting_chart_two_stroke.htm
