Author Topic: Shocker bushes need some @ 12mm not the normal 10mm  (Read 5250 times)
« on: May 10, 2012, 11:21:29 am »
Need 2 or more shocker bushes for a CR 125 or 250 shocks top mount.
From best i can tell with the measuring stick is they have an Eye diameter of 21.30mm ID ( not sure what that makes the bush ID but must be close to same ) being about 16.20mm wide -  with the original bush eye itself being about 18-19mm wide but assume i can cut it if too wide.
Re: Shocker bushes need some @ 12mm not the normal 10mm
« Reply #1 on: May 10, 2012, 05:11:59 pm »
Try a car shock specialist Freaky , I picked up some 10, 12 and 13mm bushes with and without steel insert for $2.50 each. Cheers
« Reply #2 on: May 11, 2012, 12:18:57 am »
What sort of car shock place ? like a no bull one or whats the retail name for the one you got into ?
« Reply #3 on: May 11, 2012, 11:23:58 pm »
Was previous local no bull one , has new fancy franchise owners and store now ,not knowing what their like myself but had some ho hum reports hence not naming them first up Freaky.
« Reply #4 on: May 13, 2012, 08:51:09 pm »
do they still have the steel inserts in them still ?
« Last Edit: May 13, 2012, 08:53:59 pm by Freakshow »
« Reply #5 on: May 14, 2012, 01:21:49 pm »
How much walter as per spec's above to fit into that Honda CR shock mount?  and if so... can you post some out.  Refundable if they dont fit in ?
« Reply #6 on: May 14, 2012, 02:38:03 pm »
Yes steel in or without steel. Still  the Sus Shop( :D) is local for you and appears to have a good selection., take a sample and be happy. Cheers
« Reply #7 on: May 14, 2012, 03:03:14 pm »
This is where I  source my bushes from ;) ;)
http://www.polytuff.com.au/
« Reply #8 on: May 14, 2012, 04:24:57 pm »
One day I was desperate for a shock bush to replace a flogged out on an old Works shock so I went behind my local Selbys Suspension shop on a Sunday morning and scooped 8 old 10 car shockies with good bushes out of their skip bin. I'm still using them!
« Reply #9 on: May 15, 2012, 02:27:23 pm »
yes i just though the 21.30 part was a funny size ? i have nothing in about 10 brands of shocks that comes close... plus i need the 12mm and the steel insert is too tough for me to even drill wider......
« Reply #10 on: May 15, 2012, 04:14:44 pm »
Kerry, they are a piece of piss to make , do you have access to a lathe or know of someone local whom owes you a favour ;)    As you buy the "poly tuff "   .... shackle bush ( JX  30mm OD x 30W x 12.3 ID )  trim it up to size and turn up a internal bush.
« Reply #11 on: May 15, 2012, 05:06:08 pm »
OK where does the poly tuff come from CBC ?
« Reply #12 on: May 15, 2012, 06:25:56 pm »
look back a couple of posts  ... they cost $2-50 each to buy
Rm Exhaust mount redone ....
