Marque Remarks
Honda
Shocker bushes need some @ 12mm not the normal 10mm
Topic: Shocker bushes need some @ 12mm not the normal 10mm (Read 5589 times)
Freakshow
Superstar
Adelaide, SA - looking for a "YZA" tank
May 10, 2012, 11:21:29 am »
Need 2 or more shocker bushes for a CR 125 or 250 shocks top mount.
From best i can tell with the measuring stick is they have an Eye diameter of 21.30mm ID ( not sure what that makes the bush ID but must be close to same ) being about 16.20mm wide - with the original bush eye itself being about 18-19mm wide but assume i can cut it if too wide.
74 Yamaha flattracker's
70 Jawa 2 valve speedway's
For sale - PRE 75 Yamaha MX stuff, frame, motors and parts also some YAM DT1,2,A and Suzi TS bikes and stuff
Tim754
Northern Country Victoria
Re: Shocker bushes need some @ 12mm not the normal 10mm
May 10, 2012, 05:11:59 pm »
Try a car shock specialist Freaky , I picked up some 10, 12 and 13mm bushes with and without steel insert for $2.50 each. Cheers
Freakshow
Superstar
May 11, 2012, 12:18:57 am »
What sort of car shock place ? like a no bull one or whats the retail name for the one you got into ?
Tim754
May 11, 2012, 11:23:58 pm »
Was previous local no bull one , has new fancy franchise owners and store now ,not knowing what their like myself but had some ho hum reports hence not naming them first up Freaky.
Freakshow
Superstar
Reply #4 on:
May 13, 2012, 08:51:09 pm »
do they still have the steel inserts in them still ?
Last Edit: May 13, 2012, 08:53:59 pm by Freakshow
Freakshow
Superstar
Reply #5 on:
May 14, 2012, 01:21:49 pm »
How much walter as per spec's above to fit into that Honda CR shock mount? and if so... can you post some out. Refundable if they dont fit in ?
Tim754
Reply #6 on:
May 14, 2012, 02:38:03 pm »
Yes steel in or without steel. Still the Sus Shop(
) is local for you and appears to have a good selection., take a sample and be happy. Cheers
Reply #7 on:
May 14, 2012, 03:03:14 pm »
This is where I source my bushes from
http://www.polytuff.com.au/
Superstar
Reply #8 on:
May 14, 2012, 04:24:57 pm »
One day I was desperate for a shock bush to replace a flogged out on an old Works shock so I went behind my local Selbys Suspension shop on a Sunday morning and scooped 8 old 10 car shockies with good bushes out of their skip bin. I'm still using them!
Freakshow
Superstar
Reply #9 on:
May 15, 2012, 02:27:23 pm »
yes i just though the 21.30 part was a funny size ? i have nothing in about 10 brands of shocks that comes close... plus i need the 12mm and the steel insert is too tough for me to even drill wider......
Reply #10 on:
May 15, 2012, 04:14:44 pm »
Kerry, they are a piece of piss to make , do you have access to a lathe or know of someone local whom owes you a favour
As you buy the "poly tuff " .... shackle bush ( JX 30mm OD x 30W x 12.3 ID ) trim it up to size and turn up a internal bush.
Freakshow
Superstar
Reply #11 on:
May 15, 2012, 05:06:08 pm »
OK where does the poly tuff come from CBC ?
Reply #12 on:
May 15, 2012, 06:25:56 pm »
look back a couple of posts ... they cost $2-50 each to buy
Rm Exhaust mount redone ....
Marque Remarks
Honda
