Author Topic: Standard gearing for a TM 250 please  (Read 5299 times)
Simo63
« on: May 08, 2012, 02:11:41 pm »
Can anyone tell me what the standard gearing should be or where I can find it?
John's old TM250 is geared for flat track and will do about a 100 in first  :o .  I need to gear it down for MX  :)
Craig
Offline Tahitian_Red
  • Mugen ME480
Re: Standard gearing for a TM 250 please
« Reply #1 on: May 08, 2012, 03:08:41 pm »
Alpha Sports shows 15-45 for a 1974 TM250L.
The "Factory Novice"
California, USA
« Reply #2 on: May 08, 2012, 03:59:31 pm »
Craig .... 50 on the rear is the go, and you get to use all 5 gears  ;)
14 - 45 is std
Simo63
« Reply #3 on: May 08, 2012, 04:41:25 pm »
14 - 45 is std
Thanks Oldfart, so that's 14 - 50?
« Reply #4 on: May 08, 2012, 05:56:23 pm »
I concur with oldfart - I have been running 14 - 46/47 for ages and is too tall. Hardly ever used top and was a bit too slow on the pick up. I have a 50 sitting in the shed to go on based on oldfarts recomendations at CD8
Steven
« Reply #5 on: May 08, 2012, 05:59:39 pm »
13 - 50 short /tight tracks and   14 -50 on longer more flowing suits me .... but you might want to try  14-50  and 15 -50
Simo63
« Reply #6 on: May 11, 2012, 02:17:35 pm »
Thanks for advice Oldfart but I've now run into another problem.  My local bike shop can't supply a 50T rear sprocket, nor a 13T front??  They have access to most suppliers and even took a stencil of my current 41T to send to their suppliers however the best they can do is a 42T rear and 15T front.
Any advice as to whom I can source both a 50T rear and 13T front?
« Reply #7 on: May 11, 2012, 03:12:10 pm »
I take it you are now running  520 pitch chain   ???? as you have a larger selection to choose from               ( 525 pitch is STd on the old girls )
I had my rear made by "John Titmans" not fuggin cheap..... now have something to copy from and will be buying blanks and making my own.
http://www.jtr.com.au/pdfs/talon/talon_blank_alloy_sprockets.pdf
« Last Edit: May 11, 2012, 03:27:30 pm by oldfart »
Simo63
« Reply #8 on: May 11, 2012, 03:46:08 pm »
I think it's 520 pitch but will check to confirm.  So Titman's is my only local option?
Gees if I could ge a 12T front I would be right with a 42T rear .. found an 11T for an RL but that's likely to be 525 pitch I guess?
I can't believe I just can't buy a sprocket ready to go.
Offline Suzukal
« Reply #9 on: May 11, 2012, 05:27:44 pm »
The Suzuki parts list has the standard gearing at 15/40T. Like you said, way, way, way off what you need.
I'm running 13/42 ( 520 chain )( you get to use all the gears ).
you can get sprockets from any bike shop that sells JT Sprockets.
13T front sprocket is JFT 431-13
fits:...RM250 A/B/C/C2 - RM370 A/B - RM400 C - PE250 B/C/N/T/X
other available sizes 11,12,13,14,15
42T back sprocket is JTR 820
fits:...DR250 1982-87 - SP370 - SP400
I can't remember the exact prices but they were cheap.
Simo63
« Reply #10 on: May 16, 2012, 09:46:03 pm »
Thanks everyone.  I have a new 12 and 13T front sprockets on their way from JT as I already have a rear 41.  I figure the 12/41 should be just under the 14/50 so that should be close enough for a start.  I already have a 14T front so will chase a 42/43/44 rear if I need to go up a little bit.
Hopefully get the old girl down to Nudgee for the BMCC practice day this comning Saturday  ;D
Craig
