Author Topic: PE 250  (Read 2726 times)
Offline odd1
PE 250
« on: April 25, 2012, 05:38:50 pm »
81 PE 250 oil weight and height from top of tubes without springs
Offline SimonC
Re: PE 250
« Reply #1 on: April 26, 2012, 11:25:02 am »
Is there a sort of standard height from the top of tubes that you can use as a starting point for mostbikes?
Offline Canam370
Re: PE 250
« Reply #2 on: April 26, 2012, 11:29:30 am »
No standard height from the top but if the damper tube is covered by the oil when fully compressed that'd be a good starting point.
Re: PE 250
« Reply #3 on: April 26, 2012, 04:06:29 pm »
T- X models
Std =  180mm      ......   level range   165 > 195 mm
Std air pressure    ......   8.5psi        max    35 psi
I tend to use   15w   Castrol fork oil C/O Supercheap auto
« Last Edit: April 26, 2012, 06:18:43 pm by oldfart »
Offline odd1
Re: PE 250
« Reply #4 on: April 26, 2012, 07:40:59 pm »
Thank you.
