Marque Remarks
Suzuki
PE 250
Topic: PE 250 (Read 2727 times)
odd1
PE 250
April 25, 2012, 05:38:50 pm »
81 PE 250 oil weight and height from top of tubes without springs
SimonC
B-Grade
Re: PE 250
April 26, 2012, 11:25:02 am »
Is there a sort of standard height from the top of tubes that you can use as a starting point for mostbikes?
Canam370
Re: PE 250
April 26, 2012, 11:29:30 am »
No standard height from the top but if the damper tube is covered by the oil when fully compressed that'd be a good starting point.
Re: PE 250
April 26, 2012, 04:06:29 pm »
T- X models
Std = 180mm ...... level range 165 > 195 mm
Std air pressure ...... 8.5psi max 35 psi
I tend to use 15w Castrol fork oil C/O Supercheap auto
Last Edit: April 26, 2012, 06:18:43 pm by oldfart
odd1
Re: PE 250
Reply #4 on:
April 26, 2012, 07:40:59 pm »
Thank you.
Marque Remarks
Suzuki
PE 250
