Marketplace
Wanted
ke175 piston and rings
Topic: ke175 piston and rings (Read 3025 times)
misfit
C-Grade
April 13, 2012, 09:38:54 pm »
Im in need of a piston and rings to suit a ke175b in 0.5mm oversize, thanks
ty4
A-Grade
Re: ke175 piston and rings
April 13, 2012, 11:27:56 pm »
maybe , will check in the morning
James Lee
April 14, 2012, 06:41:04 am »
I have a complete engine with new piston and rings here,also all the electrics,carby pipe etc,eveything to run it.I was going to use it in a go kart.There is some other bits and peices I keep from the bike too.You can have the lot for $250.
misfit
C-Grade
April 15, 2012, 08:13:31 pm »
Well that would also work. Im in the Lockyer Valley, Queensland are you anywhere near there James? If not what about you ty4?
James Lee
April 16, 2012, 07:51:59 am »
Im in northern nsw about an hour out of tenterfeild.Im happy to post it all as long as it doesnt weight too much for Aust post.
misfit
C-Grade
April 16, 2012, 09:05:59 pm »
Hey I just looked at Australia posts website, they can do items up to 20kg and the bottom end of the motor weighs about that much alone so it looks like its gunna be a no-go. thanks anyway
misfit
C-Grade
April 16, 2012, 09:18:12 pm »
that first post should have said 1.0mm oversize
Marketplace
Wanted
