Author Topic: ke175 piston and rings  (Read 3018 times)
Offline misfit
« on: April 13, 2012, 09:38:54 pm »
Im in need of a piston and rings to suit a ke175b in 0.5mm oversize, thanks
Offline ty4
Re: ke175 piston and rings
« Reply #1 on: April 13, 2012, 11:27:56 pm »
maybe , will check in the morning
Offline James Lee
« Reply #2 on: April 14, 2012, 06:41:04 am »
I have a complete engine with new piston and rings here,also all the electrics,carby pipe etc,eveything to run it.I was going to use it in a go kart.There is some other bits and peices I keep from the bike too.You can have the lot for $250.
Offline misfit
« Reply #3 on: April 15, 2012, 08:13:31 pm »
Well that would also work. Im in the Lockyer Valley, Queensland are you anywhere near there James? If not what about you ty4?
Offline James Lee
« Reply #4 on: April 16, 2012, 07:51:59 am »
Im in northern nsw about an hour out of tenterfeild.Im happy to post it all as long as it doesnt weight too much for Aust post.
Offline misfit
« Reply #5 on: April 16, 2012, 09:05:59 pm »
Hey I just looked at Australia posts website, they can do items up to 20kg and the bottom end of the motor weighs about that much alone so it looks like its gunna be a no-go. thanks anyway
Offline misfit
« Reply #6 on: April 16, 2012, 09:18:12 pm »
that first post should have said 1.0mm oversize
