Author Topic: RM 125 CDI  (Read 5055 times)
Offline Nipper
RM 125 CDI
« on: March 28, 2012, 10:38:28 pm »
Are the CDI units for the RM 125 A and the RM 125 B interchangeable ? I have a RM 125 B motor and stator but have the RM 125 A CDI. Were ther any differences between these CDI units.
BEARVMX
Re: RM 125 CDI
« Reply #1 on: March 31, 2012, 09:23:07 pm »
Gidday both rm125a & b 1976, 1977 same part numbers cdi, stator and flywheel as shown on alpha sports suzuki Bear
Offline PERM250
Re: RM 125 CDI
« Reply #2 on: April 01, 2012, 07:32:55 pm »
hi i think the 77 and 78 are the same 32900-41321 and the 76 number ends in 320
Offline Nipper
Re: RM 125 CDI
« Reply #3 on: April 02, 2012, 09:49:41 am »
Thanks guys that was the answer I was hoping for, I can just bolt on connect and the motor should hopefully run. Cheers.
Re: RM 125 CDI
« Reply #4 on: April 02, 2012, 01:17:34 pm »
I would be taking out the woodruff key and moving the flywheel to correspond with the timing stated in the manual
Offline Nipper
Re: RM 125 CDI
« Reply #5 on: April 02, 2012, 02:31:57 pm »
Thanks Lozza, if I remove the woodruff key wouldnt the rotor be prone to moving?
Re: RM 125 CDI
« Reply #6 on: April 02, 2012, 03:55:31 pm »
No (for the 1000th time  ;D) the taper holds the rotor in place not the woodruff key.The key is for easy of assembly at the factory/dealers with apprentices. With the rotor lapped with valve grinding paste(only thing a 4T is good for) and a light tap with a mallet will require a puller to dislodge it.
Offline vmx42
Re: RM 125 CDI
« Reply #7 on: April 02, 2012, 04:07:00 pm »
getting a bit tetchy there eh Lozza... sorry, but that is the downside of being a Guru!!!  ;D
Montynut
Re: RM 125 CDI
« Reply #8 on: April 02, 2012, 04:43:54 pm »
I think Lozza was being conservative must be 10000 times easy. Woodruff keys are the work of the devil >:(
Offline Nipper
Re: RM 125 CDI
« Reply #9 on: April 02, 2012, 05:04:31 pm »
Ah there we go I am learning something new all the time ,thanks Lozza.
Re: RM 125 CDI
« Reply #10 on: April 02, 2012, 05:21:38 pm »
Benefits of old age Jeff (not that you would know about that yet  :D)
Offline vmx42
Re: RM 125 CDI
« Reply #11 on: April 03, 2012, 08:36:39 am »
I'm catching you faster than you know Lozza!!  ;)
Re: RM 125 CDI
« Reply #12 on: April 03, 2012, 09:11:57 am »
Wouldn't there be enough movement in the slotted backing plate to take up any amount needed?
Re: RM 125 CDI
« Reply #13 on: April 03, 2012, 02:03:26 pm »
Only the timing light knows the answer to that ;)
