Author Topic: MOMS new rule - All Disciplines  (Read 6541 times)
Offline Brian Watson
  • First Penton in OZ
« on: February 24, 2012, 04:42:21 pm »
Hey Guys...see the new 2012 rule as follows :
12.8.8.6 A chain guard made of suitable material must be fitted in a way to prevent trapping between the lower drive chain run and the final drive sprocket at the rear wheel
This will mean that Classic Motocross must comply..will mean some work for many... :P
Re: MOMS new rule - All Disciplines
« Reply #1 on: February 24, 2012, 04:58:26 pm »
YEr been looking at this.  trying to figure out an easy fix........
first thought was cardboard and zip ties, but not sure when it gets wet.....  other ideas that just clamp on considered....
« Reply #2 on: February 24, 2012, 05:35:06 pm »
Well..if you can get a hold of a "modern" bike chain guide / roller assembly.... they are closed (generally) along the bottom...this may help as an idea...
« Reply #3 on: February 24, 2012, 05:46:03 pm »
What bikes don't have these from factory? All of the old Yamahas do, everything with long travel do...
« Reply #4 on: February 24, 2012, 06:00:19 pm »
Most Pre 78 and 75  Suzukis  will need to be Modified with a ice cream  lid  ;)
Offline oldyzman
  • 250 two stroke!
« Reply #5 on: February 24, 2012, 08:37:38 pm »
There is that plastic flute that they use to make realestate signs out of like plastic cardboard, coupled with cable ties...
Curly3
« Reply #6 on: February 24, 2012, 09:18:19 pm »
Change the record Wally, I know who you're shooting at and it may have been funny, once.
Dirt Track Sliders never had them from original, from memmory I can't recall any of the early MX style bikes that were used on DT having them either, they were removed or never there.
I understand where they're coming from, but really, what is stopping someones hand from going into the spokes of a wheel? ??? ???
« Reply #7 on: February 24, 2012, 09:58:31 pm »
a chain tensioner isnt a factoy finger guard  most are too far away from the sprocket to really count as a cover.
Offline JAP 454
  • See Ya at the Skids
« Reply #9 on: February 24, 2012, 10:31:32 pm »
Maybe it's a disease that's drifted in from overseas, from the '09 Antig catalogue
Crappy pic, I know , best I could do
Foss
Offline ji107
« Reply #10 on: February 24, 2012, 10:41:25 pm »
This rule has been in RR for some years now, and some Historic RR bikes chose to fit them also.
The rule is here to stay, so it would be a good idea to make something that looks a bit professional tan ice cream bucket plastic or coreflute.
Aluminium ones are easy to make and look good.
There aer ads for RR type ones on the 2010 MOMs pages 140 & 149
Offline JAP 454
« Reply #11 on: February 24, 2012, 11:03:56 pm »
Page 140 and 149 of the 2011 moms, Here's the link
http://www.zapracing.com.au/zapcart/index.php?act=viewCat&catId=25
Foss
« Reply #12 on: February 24, 2012, 11:12:08 pm »
The first Elsinores and RM's had just a small single roller chain guide. In most cases a modern chain guide (genuine or aftermarket) will bolt on without much hassle.
Curly3
« Reply #13 on: February 24, 2012, 11:29:19 pm »
Well there you go Al, now that you've pointed that out the modern Speedway bikes have something similar to that.
Probably a good idea but really, how far do you go?
There is a Speed limit on MX, soon there'll be an age limit & we'll all be f*#@ed.
Thanks for the PM Walter, what I was talking about was the re-curring " Minibike Mum " reference.
« Reply #14 on: February 25, 2012, 12:41:22 am »
The first Elsinores and RM's had just a small single roller chain guide. ....
[/quote]
Yeah, OK. http://www.theowencollection.com/73Elsinore.htm
A small piece of rigid metal or plastic sheet would easily make a CR or RM/TM chain guide comply with the new rule.
