Author Topic: CR 250  (Read 5298 times)
Offline YUMASTEPSIDE
CR 250
« on: February 14, 2012, 10:14:45 am »
What sort of dollars would you pay for a 79-80 CR250 Husky in reasonable condition ??? ???  Its a bit low on compression but everything else looks in pretty good shape??
                           Roger
Offline HVA61
Re: CR 250
« Reply #1 on: February 14, 2012, 10:36:41 am »
$2,200.00 tops
Re: CR 250
« Reply #2 on: February 15, 2012, 03:38:34 pm »
Now, the next question...................Will the gears from a '77WR fit a '79-80CR box??...........back in the '70s we used to put the last 2 gears from a WR into a CR for enduro's, as I have a '77 WR motor, I was hoping they might fit ??? ;D
                        Roger
Offline HVA61
Re: CR 250
« Reply #3 on: February 15, 2012, 04:10:49 pm »
Most gears will interchange, but you would be best off just using the complete WR or a OR cluster.
You should consult the manual and do a comparison on the gear numbers etc.
If the engine is actually a 1980 model the barrel is not interchangable with the 1979 and earlier models as the stud pattern is different
Re: CR 250
« Reply #4 on: February 15, 2012, 04:55:19 pm »
........thanks for that, I have a play and see what happens ;)
                        Roger
Offline Brian Watson
  • First Penton in OZ
Re: CR 250
« Reply #5 on: February 15, 2012, 05:48:37 pm »
You will also need to chnage the gearbox bearings also... as lay shaft / mainshaft sizes changed from 1977 thru to 1980 ...can't just shove in an early gear set into a later (post 79 me thinks) set of cases..
Offline shorelinemc
  • life sucks&then you die
Re: CR 250
« Reply #6 on: February 17, 2012, 04:31:42 pm »
nice 78 on ebay at the moment
Re: CR 250
« Reply #7 on: February 17, 2012, 05:20:55 pm »
............there's nothing like self promotion ! ;D ;)
                            Roger
Offline HVA61
Re: CR 250
« Reply #8 on: February 17, 2012, 07:15:13 pm »
the 78 model is real nice and the ergo's were superb
The 79 model is very very tall , but they  are still real nice rides. Someone correct me if I'm wrong , but i think the 79 was the tallest bike of that era.
They have  35mm forks and they are quite long and they flex "a lot ", but they work real well when set up correctly.
Offline shorelinemc
Re: CR 250
« Reply #9 on: February 18, 2012, 09:26:06 am »
                            Roger
  when opportunity knocks ;D
Offline Barronvmx
Re: CR 250
« Reply #10 on: February 22, 2012, 12:18:09 pm »
Just finishing a WR250 79 motor with 80 frame. I changed the front to 40mm and a longer swingarm from a 1981 frame to increase the wheel base.
Just remember they are a timed gear box and need to be assembled in 4th gear and the selector cog should show 2 teeth visible at the top. If you have a manual it explains it in more detail.
Just PM me if you require any info.
Glenn.W
BMCC
Huskies
CR250 1972, CR400 1972, SC125 1973, CR250 1975GP, WR250 1979/80, XC125 1983, TX510 1983, XC125 1984 project, CR250 1984 project
Honda's
SL100 1971, XL100 1974, Hondasaki 210, XL185 1981 project
Jawa's
1959 250 project, 1969 175 trail boss project.
Sachs 1969 125
