Author Topic: What's going on with this ?  (Read 33126 times)
Offline YZ250H
  • Back in QLD Baby !
« on: February 12, 2012, 07:39:01 pm »
Obviously a mod, but what is the shock from and why would you do it  :-\
maico police
Re: What's going on with this ?
« Reply #1 on: February 12, 2012, 07:45:41 pm »
I'd say it's not the standard shock for the bike and that bit on the end is to make up the difference. I had the same thing on the 80 J that I bought. Beware other such modification..... ::)
Offline YZ250H
« Reply #2 on: February 12, 2012, 08:02:41 pm »
thanks Ross,
Thankfully whoever did it had the good sense to make it removable  8)
I will give it a chance as it is and see how it goes.  250C shocks don't exactly grow on trees ::)
Offline motomaniac
« Reply #3 on: February 12, 2012, 08:05:14 pm »
You need to show the other end of the shock but Im calling it a DT shock , similar to later yz 's but no dampening adjuster on the shaft
« Reply #4 on: February 12, 2012, 08:09:27 pm »
Yeh the YZB /C and mx b's shock had a long shaft though the end and two nuts and 3or2 rubber bushes the shock in the photo looks like a 77 plus dt shock ( no adjustment )
Iain
Offline YZ250H
« Reply #5 on: February 12, 2012, 08:18:35 pm »
It does have some sort of weird adjustment as per below  :-\
regardless of all that it certainly isn't a C shock as there is no reservoir anywhere to be seen
Offline David Lahey
« Reply #6 on: February 12, 2012, 08:31:06 pm »
That one will make an almighty bang if it bottoms out. The standard YZC shock uses the rubber mounting cushions at the front end to absorb the impact when the shock bottoms (spring coils all touch when it bottoms). That set up in the photo has no cushion on the mounting or on the shock shaft so something may well bend if it ever bottoms hard.
previous pseudonym feetupfun
Offline YZ250H
« Reply #7 on: February 12, 2012, 08:35:54 pm »
I see Walter has one for sale.  I will investigate that ;).
Would be good to know what the other one is as it works very well and is in very good nick.  No leaks or rust on the shaft.
Offline steveo247
« Reply #8 on: February 12, 2012, 09:10:03 pm »
pretty sure dad has a surplus rear shock he may let go!
i dont know what that is, but it looks like a few years later model yz80 to me.
« Last Edit: February 12, 2012, 09:15:17 pm by steveo247 »
Offline steveo247
« Reply #9 on: February 12, 2012, 09:14:20 pm »
as for why would you do it.
becuase the rear shocks would have been really hard to come by before the internet was around, and it would have been easier/cheaper to make that one fit rather than get the correct item. or fix the correct item.
and as you would likely know -
here is the standard setup (tho the 125 version)
FWIW this is 125X shock on top and 125C model on bottom
« Reply #10 on: February 12, 2012, 10:27:58 pm »
considering the bastardry seen on other resto's/paddock bashers, that mod seems rather well engineering by comparison. I'm not saying you should chrome plate it (as you've been known to do) just saying it's not complete shite relatively speaking
« Reply #11 on: February 13, 2012, 01:05:47 pm »
As motomaniac said, 99% sure that's a DT125/175 monoshock shock. That IS a dampening adjustment, but I've never felt any difference, even when they weren't seized solid.
DT250/400 monoshocks have a wider top/front mount, I think.
« Reply #12 on: February 13, 2012, 04:16:17 pm »
if you get stuck the Works Performance MX B (?) shocks fit the YZ Bs with only a small mod.
Offline YZ250H
« Reply #13 on: February 13, 2012, 05:22:46 pm »
Looking for YZC Rosco, so it should go straight on.
