Author Topic: Improving braking on an RM465Z??  (Read 7154 times)
Offline Bitten
  • Sydney, Australia
« on: February 07, 2012, 11:46:30 am »
Hi All
I am looking at trying to improve the breaking on my 465
I have new pads and cables and adjusted the front as much as I can and while OK it does not install any great confidence to open her right up
Some questions....
1. Can anyone recommend someone who can re-sleeve the drum in Sydney?
2. Will a 83 /84 500 Double leading shoe brake plate fit straight on or do I need the whole wheel
3. Will the whole 500 wheel fit onto an 82 465?
4. Any other simple tips to try and pull it up a bit quicker!!?
Cheers and thanks in advance
Re: Improving braking on an RM465Z??
« Reply #1 on: February 07, 2012, 12:22:43 pm »
Vandy put me onto cutting some angled slots across the brake pad material and de-glazing the lining with some sandpaper. Worked really well.
Offline vandy010
  • #789 MX125a BMCC Brisbane
« Reply #2 on: February 07, 2012, 01:00:18 pm »
actually,
what i do is to cut the slots diagonally making sure the direction of the slots send the "rubbish" to the outside of the hub and not back into it.
i also give the both the lining and the pads a quick "whip" blast with a sandblaster as it takes any glazing off of both surfaces thus giving more grip. if that makes sense.
but then again, all my bikes are Yamaha's and thier brakes as we all know, work.
well lubed cable and actuating arm in the backing plate are also a must ;)
"flat bickie"
Offline Bitten
  • Sydney, Australia
« Reply #3 on: February 07, 2012, 02:45:29 pm »
At the risk go sounding dumb .... what do you cut them with!?
« Reply #4 on: February 07, 2012, 03:33:33 pm »
An angle grinder with a metal cutting disc, the older style though (3-ish mm thick?), not those new wafer thin ones
Offline Bitten
  • Sydney, Australia
« Reply #5 on: February 07, 2012, 04:36:42 pm »
Thanks, I was cutting bricks on the weekend so it is already set up!
Can anyone recommend someone to reline the drums in Sydney?
« Reply #6 on: February 07, 2012, 06:01:29 pm »
Soooooo, where where your brakes when you ran over the top of me last year Mic? ;D
« Reply #7 on: February 07, 2012, 06:36:41 pm »
Who said it was accidental? ::)
Offline holeshot buddy
  • sunshine coast qld
« Reply #8 on: February 09, 2012, 09:43:34 pm »
try and get hold of a 1984 rm 125/250/500 twin leader brake
will fit straight on
follow me to first turn
Offline Bitten
  • Sydney, Australia
« Reply #9 on: February 10, 2012, 10:11:34 am »
Hi Holeshot
Just confirming that all I need is the backing plate (+ other bits) and that will slot straight into the existing drum of the 1982 465?
I appreciate your support
Offline AdamN
« Reply #10 on: February 10, 2012, 01:18:45 pm »
I will stand corrected, but I think you need the hub to suit as well, as the dia. is smaller on the twin leading shoe set up. The cable looks different as well as the left lower fork leg as well. Mine was a complete front end swap so I didn't play around with what fits etc. I'm sure one of the Suzuki guru's here will give you the facts.
ADam
'82 PE175Z, '92 YZ125D1, '93 WR500ZE, '13 KTM350EXC-F, '16 Husky TE300
Offline Bitten
  • Sydney, Australia
« Reply #11 on: February 10, 2012, 02:05:35 pm »
Thanks Adam
Yes looking at the Clymer manual (where I should have started) the double leading shoe brake drum diameter is 130mm versus 150mm for the single
So my next question to the brains trust is If I were to lace up an 84 hub or source a wheel will the axle and spacers all fit to the 465 forks? Looking at the manual it give the impression it does but I would like to make sure before going to the trouble and expense
As always any advice is greatly appreciated
Offline D project
« Reply #12 on: February 10, 2012, 06:53:27 pm »
81-84 125 wheels all have the same brake drum and will work with the twin leading brake.
The only problem is the backing plate won't be on the correct angle on the 465 forks.
So you may have to source another set of forks to suit, 125/250/500E, 250/500D would work.
May be best to try getting yours working first, as the twin leader wasn't that much better ::)
« Reply #13 on: February 10, 2012, 07:39:23 pm »
Thanks Adam
You need the forks with the shrunk on axle mounts and the slot for the backing plate lug is at 90degrees to the fork leg to fit the twin leading shoe backing plate. Pretty sure '82-'84 forks will fit the twin leader backing plate.
« Reply #14 on: February 10, 2012, 07:39:36 pm »
You can get the last drum XL 500 front wheel which had a awesome drum brake , downside was it's heavy as in really heavy. But it is an easy retro fit
