Author Topic: Clutch won't work  (Read 3466 times)
Tom
Clutch won't work
« on: March 18, 2008, 05:53:59 pm »
G'day all i got a 1981 cr125 i rode it bout 2 - 3 weeks ago no problems pulled it out 2day started it went 4 a idle round and pulled in the clutch dosent work quikly stopped the bike before it went to crazy  :o no matter how much i adjust it , it dosent seem to let the back wheel move whilst in gear i dont understand it  :-[  any help much appreciated thanks Tom
Offline cyclegod
  • Sunny PERTH W.A
    • cyclegod on "youtube"
Re: Clutch won't work
« Reply #1 on: March 18, 2008, 06:01:53 pm »
1, Dismantle clutch
2, Clean clutch plates
3, Check clutch basket ribs for slots (caused by the plates) replace if bad
4, reassemble and use fresh correct oil
If its still faulty consult a mechanic
Ban BLACK rims NOW
gerpster
« Reply #2 on: March 18, 2008, 08:15:13 pm »
Clutch plates stuck together????
« Reply #3 on: March 18, 2008, 09:18:08 pm »
So, it is not disengaging when you pull the h/bar lever in?
To go from working to not working is very strange. Something is broke or stuck. We need more info. Does the h/bar lever pull in smoothly/normally?
« Reply #4 on: March 18, 2008, 11:20:52 pm »
 if the plates catch in the basket they wont release
 If its not that its open her up and have a look time
Offline suzuki27
« Reply #5 on: March 30, 2008, 06:43:35 pm »
Might be a broken clutch rod? Definately dismantle and check everything is where it should be etc.
