Clubroom
Bike Talk
Clutch won't work
Topic: Clutch won't work (Read 3457 times)
Tom
Clutch won't work
March 18, 2008, 05:53:59 pm »
G'day all i got a 1981 cr125 i rode it bout 2 - 3 weeks ago no problems pulled it out 2day started it went 4 a idle round and pulled in the clutch dosent work quikly stopped the bike before it went to crazy
no matter how much i adjust it , it dosent seem to let the back wheel move whilst in gear i dont understand it
any help much appreciated thanks Tom
cyclegod
Sunny PERTH W.A
Re: Clutch won't work
March 18, 2008, 06:01:53 pm »
1, Dismantle clutch
2, Clean clutch plates
3, Check clutch basket ribs for slots (caused by the plates) replace if bad
4, reassemble and use fresh
correct
oil
If its still faulty consult a mechanic
Ban BLACK rims NOW
gerpster
March 18, 2008, 08:15:13 pm »
Clutch plates stuck together?
mx250
March 18, 2008, 09:18:08 pm »
So, it is not disengaging when you pull the h/bar lever in?
To go from working to not working is very strange. Something is broke or stuck. We need more info. Does the h/bar lever pull in smoothly/normally?
pokey
March 18, 2008, 11:20:52 pm »
if the plates catch in the basket they wont release
If its not that its open her up and have a look time
suzuki27
March 30, 2008, 06:43:35 pm »
Might be a broken clutch rod? Definately dismantle and check everything is where it should be etc.
Clubroom
Bike Talk
Clutch won't work
