Marketplace
Wanted
Honda CR125M crank seal source
Topic: Honda CR125M crank seal source (Read 3834 times)
nifty
Novice
January 12, 2012, 08:03:04 am »
Trying to locate an Aus source or anyone that may have a stock of crank seals to suit the Honda CR 125M engine, 1974. The seal I require is the 28 x 56 x 9, Honda part 91203-360-003.
Noel
Re: Honda CR125M crank seal source
January 12, 2012, 09:18:30 pm »
Hi Nev.
the last seals I got from Craig at MMT,
I think they were Pro x, the set before that from Red Devil had Kawasaki part numbers on them.
Hth.
Noel
Last Edit: January 12, 2012, 09:40:34 pm by Noel
Lozza
January 12, 2012, 11:31:17 pm »
I have a Pro-X one here but it is by 8mm wide not 9mm
nifty
Novice
January 13, 2012, 07:22:14 am »
Thanks Noel & Lozza, I'll try Craig as I'll have to take the crank to him at any rate, snapped the pin in half at Buladelah, not sure why there was no heat stress evident!
Shaun G
Sydney, NSW
Reply #4 on:
January 13, 2012, 09:30:12 am »
Hey Nev I got my last set for the '76 off Bruce so maybe you could get them from Les now???
Shaun
www.fullloadmotorcycletransport.com
www.facebook.com/FullLoadMotocycleTransport
nifty
Novice
Reply #5 on:
January 15, 2012, 10:03:59 am »
Shaun, Magoo supplied my last one as well, good thought, I'll try Les when he returns from holidays. Cheers.
Stewart Allen
A-Grade
Reply #6 on:
February 12, 2012, 02:08:37 pm »
Hi Nev,
I have a couple if you are still looking.
Stewart
CHEERS STEWART
Doing it to old things is fun
# 74 Heaven
IT490 Will be going one day soon
CR125M
SL175 bitza
IT250D needs work
CR250RE Not going as yet
YZ125F
bazza
Reply #7 on:
February 12, 2012, 02:59:31 pm »
"Econohonda" New Zealand
Once you go black you will never go back - allblacks
Embrace patina
Marketplace
Wanted
