Author Topic: Removing clear coat from polished alloy?  (Read 1711 times)
Offline Rosco86
  • Brisbane
« on: January 08, 2012, 02:01:27 pm »
Have some parts that have had the alloy polished and then clear coated. Looking to remove clear coat as it has lifted in spots. Difficulty is other areas of the part are painted and I don't want to affect them. Ideas?
Offline David Lahey
Re: Removing clear coat from polished alloy?
« Reply #1 on: January 08, 2012, 03:53:48 pm »
If you want to avoid using paint stripper on the clear, it can be removed with fine wet-and-dry paper but depending on the complexity of the shape of the item, it can be quite labour intensive.
previous pseudonym feetupfun
Offline lyle2212
« Reply #2 on: January 08, 2012, 06:51:51 pm »
ACETONE
