Clubroom
Tech Talk
Removing clear coat from polished alloy?
Topic: Removing clear coat from polished alloy? (Read 1714 times)
Rosco86
A-Grade
Brisbane
January 08, 2012, 02:01:27 pm »
Have some parts that have had the alloy polished and then clear coated. Looking to remove clear coat as it has lifted in spots. Difficulty is other areas of the part are painted and I don't want to affect them. Ideas?
David Lahey
Gladstone, Queensland Australia
Re: Removing clear coat from polished alloy?
January 08, 2012, 03:53:48 pm »
If you want to avoid using paint stripper on the clear, it can be removed with fine wet-and-dry paper but depending on the complexity of the shape of the item, it can be quite labour intensive.
previous pseudonym feetupfun
lyle2212
B-Grade
January 08, 2012, 06:51:51 pm »
ACETONE
Clubroom
Tech Talk
