Suzuki
74 Tm timing BTDC please
All
Topic: 74 Tm timing BTDC please (Read 8371 times)
Freakshow
Superstar
October 10, 2011, 12:42:39 pm »
anyone kow off the top of there head the74 Tm timing BTDC please ? is it like 2.3mm ?? i cant find the book
74 Yamaha flattracker's
70 Jawa 2 valve speedway's
Freakshow
Superstar
Re: 74 Tm timing BTDC please
October 11, 2011, 12:44:04 pm »
Surely someone must know
brent j
Darwin, NT. Suzuki tragic, RL250M TS90MX PE250B
October 11, 2011, 03:09:35 pm »
I'll check at home tonight. I know I've read it but can't remember off-hand
Freakshow
Superstar
October 11, 2011, 03:43:45 pm »
same i thought maybe 1.8 or 2.3 but im guessing, did a quick net search and came up empty
brent j
October 11, 2011, 05:42:58 pm »
Freaky from your other post I see you want the specs for a 250? I just assumed (that word again) it was for a 125. I have the numbers for a 250 as well
suzuki27
October 11, 2011, 05:55:37 pm »
Freaky ,on my RH 250 with a bore & stroke of 70 x 64mm the ignition timing is set at 2.7- 2.8mm BTDC.
brent j
October 11, 2011, 09:41:34 pm »
Sorry Freaky, my service data book doesn't give a timming setting for TM's.
The only timming setting I have is for a 125.
Freakshow
Superstar
Reply #7 on:
October 11, 2011, 11:18:25 pm »
i got three motors here none with the stators on them, youd think i would have checked on that, before i pulled them all off at some point.... doh
must be an online manual somewhere.
Freakshow
Superstar
Reply #8 on:
October 12, 2011, 12:14:34 pm »
yoUR KILLING ME WHERE ARE ALL THE sUZUKI FILE S? dOC SURELY ONE OF YOU GUYS WOULD KNOW THIS PRITY BASIC NUMBER
halo1963
Novice
Reply #9 on:
October 12, 2011, 11:59:23 pm »
From the Clymer Manual (only lists RL AND TS 250)
on PEI modles, Ignition timing is set when the mark on the stator plate is centred at the top mounting screw
the figures given above are used to check the advance built into the black-box circuitry.These figures are checked using a degree wheel and a timing light.
Timing Inch (mm)16 degrees at 1000 RPM
Degrees (BTDC) 24 degrees at 6000 RPM
However in the specification section it statesTM 250 = 21.5 at 6000 RPM
the Suzuki 1972 service manual (the only one that I know of that is TM250 specific and have)
States 21.5 at 6000 rpm (BTDC)
Hope that helps
Regards
Halo1963
Freakshow
Superstar
Reply #10 on:
October 13, 2011, 12:41:54 am »
YEr thanks for looking but i got that same manual. DOh..
It unfortunatley talks in degrees and i dont do degree wheels, i use a Dial gauge so i was hoping somewhere out there was the spec in MM. Anyone now how to change degrees into a mm BTDC statement ?
halo1963
Novice
Reply #11 on:
October 13, 2011, 12:59:21 am »
Not sure how the dial works
How ever to convert degrees in to mm you only need to know the diameter of the circle.
My stator plate is 120 mm O/D so 120 x 3.1416 = approx 377mm this is the circumference of the stator
so divide it by 360 and you have one degree then times it by 21.5 and you get 22.5 mm
Does that help
Regards
Halo1963
tony27
Reply #12 on:
October 13, 2011, 05:20:32 am »
This worked for me
http://www.dansmc.com/mc_software2.htm
Freakshow
Superstar
Reply #13 on:
October 13, 2011, 11:15:01 am »
Wow thats all abit above my brain and skill set. I just need a number BTDC in MM. IF it was a yamaha :O), be easy as.
ill ring up the local Suzi place they must have an old service sheet with it on. I just figured all you suzi gurus would know this off ya head.
monaro308
Reply #14 on:
October 13, 2011, 01:11:53 pm »
Freaky,so far everything i've looked up on TM250 timing on Lukes suzuki tech manuals,they all say "PEI" for BTDC mm...every other bike non PEI has the timing spec.
I've been looking and come up with nada so far.
All
Suzuki
