Author Topic: 74 Tm timing BTDC please  (Read 8378 times)
Re: 74 Tm timing BTDC please
« Reply #15 on: October 16, 2011, 03:30:28 pm »
Freaky, do you have a timing light  and a 12 volt battery ???..... get back to me when you have and I will walk you through it.
« Reply #16 on: October 17, 2011, 12:37:34 pm »
NAr have never owned a timing like that worked.
Solution came to me and i Used the vibration marks on one of them to match up the old set up then cross checked it on the others and there marks -  all good now !   ;D
For Future referacne -->   First mark on rotor to stator with a Dial guage is at 2.3mm, second is 2.7mm and third is 3.2mm
So Keep these numbers for static timing a TM250 with a dial guage BTDC at the track or where ever it take you.
« Last Edit: October 17, 2011, 01:35:01 pm by Freakshow »
