Author Topic: rm370A can I fit 38mm flat slide mikuni for evo  (Read 3717 times)
Taka 100
« on: August 13, 2011, 01:23:08 am »
any one stuffed around with the 38mm flat slide mikuni on the big zook , i would like to eventually ride it in evo (is that ok by the regs? ) , ive been trying to get this bike going for glenbawn heaven, thanks
Offline Doc
Re: rm370A can I fit 38mm flat slide mikuni for evo
« Reply #1 on: August 13, 2011, 05:04:48 am »
Most definitely a yes for the flatslide on a 370 in evo and no, the 370 in evo isn't an issue ;)
Taka 100
« Reply #2 on: August 13, 2011, 07:55:42 am »
thanks for the info mate , its off a 89yz250 fingers crossed jetting will be close ,
« Reply #3 on: August 13, 2011, 08:42:17 am »
I don't think you can run a flatslide Mikuni in Evo, they are a later era carby. If you run a flatslide it has to be an EI or a Lectron.
Offline Doc
« Reply #4 on: August 13, 2011, 10:20:08 am »
18.6.0.4 Carburettors:
a) Any round-slide carburettor of a type
available pr e-1975 may be used
except the Pre-1960 class where a Mk1
Amal Concentric or period carburettor
may be used.
b) Flat-slide carburettors are prohibited on
all machines except EVO and Pre 85,
c) No reed-valves permitted on machines
up to and including Pre-1970 class
John ,the rules don't actually state which type. I can understand where you are coming from but as Taka says, it needs clarification :-\
« Reply #5 on: August 13, 2011, 10:46:54 am »
Hi Doc and welcome back..
I'm sure the rules used to state no flatslides other than period ones (EI, Lectron etc) in Evo but that latest ruling now leaves it wide open...
Offline Kane Mcguire
« Reply #6 on: August 13, 2011, 04:46:25 pm »
you are allowed any flatslide in evo.
Offline micks
« Reply #7 on: August 13, 2011, 05:24:12 pm »
next year the rule may change to period correct flat slides.
Offline huskibul
« Reply #8 on: August 13, 2011, 05:52:29 pm »
   Here we go again -shifting goalposts ! startin to sound like the B-40 sidepoint/dizzy  saga ::)
« Reply #9 on: August 15, 2011, 09:28:54 am »
  seems a little strange when the vmx revolution or evolution started that some people had trouble sourcing parts and had to run what they could within reason not all can buy period correct new  stuff it seems this has gone like the real estate market, through the roof for no sane reason just playing into the hands of some.
No real conspiracies going on, the rules are simply meant to reflect what was available at the time.
Yes, this shifting of goal posts confuses everyone.
I would have thought you would be better setting this model up for Pre 78 as it would be more comfortable there.
Offline micks
« Reply #10 on: August 15, 2011, 10:32:30 am »
taka 100 http://www.ma.org.au/fileadmin/user_upload/Documents/Reports___Minutes/2011/80010633_CMX_Comm_minutes_May_11.pdf   page 17 18.10.04 it MAY change see how much feedback the commission get. sorry got. 211 kawasaki maybe able to help with this issue. anyhow taka 100 hope this helps or has just confussed the issue more.
