Author Topic: RM370 Piston  (Read 12259 times)
Offline Toolboy
RM370 Piston
« on: July 29, 2011, 07:44:18 pm »
Gday all,
Can you use a RM400 piston in the 370 barrel??
Tim
82 RM250Z
79 RM400N
76 RM370A
74 TM400L
05 M50 Boulevard
1986 RM80G
1974 RV125
1994 DS80
2005 JR50
Re: RM370 Piston
« Reply #1 on: July 29, 2011, 09:06:57 pm »
Rick Horvat in USA has Wiseco RM370 pistons specially made. Well he may not have any left im not sure but just ask him. You may also find his details in an older VMX mag.
[email protected]
Offline lukeb1961
  • PE175N, RM80B, JR50C
    • PE175N
Re: RM370 Piston
« Reply #2 on: July 29, 2011, 09:11:32 pm »
the RM370 was 77mm*80mm and the RM400 was 80mm bore * 80mm stroke.
Re: RM370 Piston
« Reply #3 on: July 30, 2011, 10:02:17 am »
Gday all,
Tim
Yes they can
cheers Zook Doc
Re: RM370 Piston
« Reply #4 on: July 30, 2011, 11:09:58 am »
Yes you can bore the 370 cylinder out and use the '78 400 piston.
Offline Toolboy
Re: RM370 Piston
« Reply #5 on: July 30, 2011, 01:03:45 pm »
What is the difference between a 78 400 piston and a 79/80 Piston???
Is it just the single ring????
Tim
82 RM250Z
79 RM400N
76 RM370A
74 TM400L
05 M50 Boulevard
1986 RM80G
1974 RV125
1994 DS80
2005 JR50
Re: RM370 Piston
« Reply #6 on: July 30, 2011, 06:39:58 pm »
 ;D  from your professional Suzuki Doc -  all the RM400's C/N/T use the same piston, it's only the stroke that differs. 400C=402cc 400N/T=417cc
For clarification, it's only the RM370 that used double ring..all the 400's are the same piston which are single ring.
cheers A & DR
Offline Toolboy
Re: RM370 Piston
« Reply #7 on: July 30, 2011, 07:23:27 pm »
Ok...thanks for the info..so is there a .75 piston for the 370 or is it easier to get a STD 400 piston??
Tim
82 RM250Z
79 RM400N
76 RM370A
74 TM400L
05 M50 Boulevard
1986 RM80G
1974 RV125
1994 DS80
2005 JR50
Re: RM370 Piston
« Reply #8 on: July 31, 2011, 08:05:29 am »
ebay item numbers
220235250144 (RM370 0.75 piston)
190211579004 (RM370 0.75 piston rings)
Search 'RM370 piston' or '12110-41202-075' or '12110-41202' and look for the 0.75 size option.
Search 'RM400 piston' and look for the std size.
simply google search !!
cheers from your local Suzuki Doc.  ;D
Offline Toolboy
Re: RM370 Piston
« Reply #9 on: July 31, 2011, 08:28:27 am »
Hey Doc,
Thanks for the great info... ;D
You wouldnt also now about sourcing a muffler for the 370???
Tim
82 RM250Z
79 RM400N
76 RM370A
74 TM400L
05 M50 Boulevard
1986 RM80G
1974 RV125
1994 DS80
2005 JR50
Re: RM370 Piston
« Reply #10 on: July 31, 2011, 09:21:14 am »
MCS  have a universal type that  look OK
Offline Toolboy
Re: RM370 Piston
« Reply #11 on: July 31, 2011, 12:08:21 pm »
Who is MCS??...do you have a link for their web site??
Tim
82 RM250Z
79 RM400N
76 RM370A
74 TM400L
05 M50 Boulevard
1986 RM80G
1974 RV125
1994 DS80
2005 JR50
BEARVMX
Re: RM370 Piston
« Reply #12 on: August 01, 2011, 09:05:03 pm »
Gidday same gudgeon pin as rm 400 c/n/t you must use rm370 s/end bearing though, ive just rebored a rm370 cyclinder it fits the rm400 std piston without any problems Bear
Re: RM370 Piston
« Reply #13 on: August 02, 2011, 09:33:01 am »
........RM370 top bearing advice.I believe it's only the N and T models that have a different bearing due to slightly smaller dimensions, the 400C bearing is the exact same part as the RM370. #09263-18011.  ;)  :)
 Out of interest the 400C barrel also bolts straight onto the 370's.  :)
cheers Zook Nuts
Offline Toolboy
Re: RM370 Piston
« Reply #14 on: August 02, 2011, 04:02:37 pm »
VMX... thanks for the info..
I was wondering about the 400c barrel bolting onto the 370.
Do you know if this is the std coversion to the 370 for racing???
Tim
82 RM250Z
79 RM400N
76 RM370A
74 TM400L
05 M50 Boulevard
1986 RM80G
1974 RV125
1994 DS80
2005 JR50
