Author Topic: RM370 Piston  (Read 12252 times)
Re: RM370 Piston
« Reply #15 on: August 02, 2011, 05:51:25 pm »
You can bolt the 400C barrel onto the 370 but if someone see's the 400cc writen on the cylinder you won't be able to race it in pre '78.
The 370 cylinder will bore to 400 no problem, i've done it on mine because it's easier to source std 400 pistons than o/s 370 pistons.
Offline oldyzman
  • 250 two stroke!
Re: RM370 Piston
« Reply #16 on: August 02, 2011, 08:29:32 pm »
Just buy a yz400D....
Offline Toolboy
Re: RM370 Piston
« Reply #17 on: August 03, 2011, 08:50:35 am »
Is the 400 piston 1.0 oversize???
Oldyzman.... I havent noticed the yz400D as they are usually behind me... hahaha
Tim
82 RM250Z
79 RM400N
76 RM370A
74 TM400L
05 M50 Boulevard
1986 RM80G
1974 RV125
1994 DS80
2005 JR50
Offline Doc
Re: RM370 Piston
« Reply #18 on: August 08, 2011, 09:22:35 am »
Tim, you would be hypothetically looking at a 3.0mm oversize 370 piston to get to the std 400 bore. An overbore radius of 1.50mm which equates to 3.00mm when measuring the diameter.
Offline Toolboy
Re: RM370 Piston
« Reply #19 on: August 08, 2011, 06:47:16 pm »
Thanks Doc, so is there plenty of meat on the barrel to go out to this speck if required???
Tim
82 RM250Z
79 RM400N
76 RM370A
74 TM400L
05 M50 Boulevard
1986 RM80G
1974 RV125
1994 DS80
2005 JR50
Re: RM370 Piston
« Reply #20 on: August 08, 2011, 07:06:51 pm »
Tim
Yes.. like i said earlier my 370 is bored to 400cc using a std 400 piston
Offline Toolboy
Re: RM370 Piston
« Reply #21 on: August 09, 2011, 07:39:37 am »
Johnny O...did you change the jetting to help keep the piston cool???
Tim
82 RM250Z
79 RM400N
76 RM370A
74 TM400L
05 M50 Boulevard
1986 RM80G
1974 RV125
1994 DS80
2005 JR50
