Author Topic: 1977 yamaha yz400 d airbox  (Read 1714 times)
Offline worms
« on: June 28, 2011, 03:18:57 pm »
In need of a airbox if anyone has a spare?
Cheers trev
Re: 1977 yamaha yz400 d airbox
« Reply #1 on: June 28, 2011, 06:26:47 pm »
the 77 250 yz will also fit so will the 77 ITs 250/400 ,a couple more chances .
Offline worms
« Reply #2 on: June 29, 2011, 07:20:52 am »
Cheers Iainyz, I allready have a 250 on the bike , but the 250 has a smaller outlet for the boot to the carby, so to go really fast i will need the 400 box ;D
trev
Simo63
« Reply #3 on: June 29, 2011, 08:05:51 am »
trev
I don't know about that Trev .. I reckon your stubby holder "spacer" you currently use is working fine mate  :D
Offline worms
« Reply #4 on: June 29, 2011, 10:07:22 am »
it hurts when I'm going supersonic and still getting passsed and lapped, I need more air, which in turn produces more speed! stubby holders are good, but not what I'm looking for.
trev
Offline crossedup2
  • Never enough shed time.....
« Reply #5 on: June 29, 2011, 04:02:19 pm »
Worms
The 250/400 D and 400E airbox are all the same. The 250E and the F models have the larger out let on the box. Not sure if a 250E air box will fit D models because of the aluminum spine brace in the D frame, the 250E does not have this (the hole through the middle is the small size only on the D's). The air box is thicker in width and the air filter is wider on the 250E by about 2cm. I don't believe there is that big an advantage by using the later air box.
If your after supersonic speed than look for a pipe and bigger gonads.
Peter B
