Author Topic: Suzuki Forks?  (Read 2009 times)
Suzuki Forks?
« on: June 24, 2011, 08:33:15 pm »
I was told they were Suzuki RM400 forks. I can't find an exact match on the parts catalog. The main difference is these have solid mounted (not rubber mounted) handle bars.
I think they originally had fork gaiters.  Those are after market wipers/dust seals. They are 38mm.
The other distinguishing feature is what appears to be cast in number plate mounts (centre top and bottom triples).
I'm thinking of selling them if anyone is interested.
Re: Suzuki Forks?
« Reply #1 on: June 24, 2011, 08:38:04 pm »
Look like RM125B model forks or maybe PE175
« Last Edit: June 24, 2011, 08:39:39 pm by JohnnyO »
Re: Suzuki Forks?
« Reply #2 on: June 24, 2011, 08:47:29 pm »
Looking up Alpha Sport site, the PE250C comes close back the handle bar mounts are flat where these slope backwards.
Re: Suzuki Forks?
« Reply #3 on: June 24, 2011, 08:47:50 pm »
By the shape of top clamp I'd say they are Pe ....have a look behind bottom triple to see if there is a screw hole on LHS.
Re: Suzuki Forks?
« Reply #4 on: June 24, 2011, 09:02:42 pm »
Roger that ;). Looks 6mm thread.
All of the PE's I have looked up have flat handlebar mounts.
Re: Suzuki Forks?
« Reply #5 on: June 24, 2011, 09:10:09 pm »
Looking up Alpha Sport they could be a number of PE models, '80, '81, and '82, 175 and 400. Further investigation required.
Re: Suzuki Forks?
« Reply #6 on: June 24, 2011, 09:22:22 pm »
36mm forms  tubes are a give away also.
Re: Suzuki Forks?
« Reply #7 on: June 24, 2011, 09:45:32 pm »
Not sure if your saying the wipers are 38mm or the fork legs are? If they are 38mm forks i would say 82-84 PE175. If they are 36mm then i would say 80-82 PE250/400 or 80-81 PE175 or 82 DR250Z or D  Internally you can tell if they are off a early or late PE250/400.That hole on the back of the triple is the speedo cable guide hole so that will give you your answer ;)
Re: Suzuki Forks?
« Reply #8 on: June 24, 2011, 09:49:40 pm »
They are 38mm fork legs so 82-84 PE175 it is.
Offline frostype400
Re: Suzuki Forks?
« Reply #9 on: June 24, 2011, 10:07:43 pm »
I am after some 82-84 pe175 trees.
1971 tm400 and PE's
Re: Suzuki Forks?
« Reply #10 on: June 24, 2011, 10:13:38 pm »
I'll throw them in for nothing, although the forks will cost you $200 ;D.
Offline frostype400
Re: Suzuki Forks?
« Reply #11 on: June 24, 2011, 10:17:05 pm »
 :D I have forks already surely someone will want the complete set they look in good nick. :)
1971 tm400 and PE's
Re: Suzuki Forks?
« Reply #12 on: June 24, 2011, 10:30:48 pm »
They are in very good nick. Someone has polished the triples to a chrome like finish. The fork legs are dirty and unpolished but with scarcely a mark on them (unusual for dirt bikes, normally have a few battle scars from passing rocks etc).
