Author Topic: id of motor  (Read 5739 times)
SPANISH ARMADA
id of motor
« on: May 25, 2011, 07:52:58 pm »
picked up an engine tonight the price was right complete with ignition and carby i know its a 400 engine prefix is 501 can someone  tell me what model its out of thanks chris
Offline motomaniac
Re: id of motor
« Reply #1 on: May 25, 2011, 08:23:45 pm »
mid 70's DT400 but wait for comfirmation on that. ???
Re: id of motor
« Reply #2 on: May 25, 2011, 08:31:11 pm »
1976 DT400C
SPANISH ARMADA
Re: id of motor
« Reply #3 on: May 25, 2011, 08:38:04 pm »
sorry but i fu---ed up  ??? no is 510 has no oil pump i noticed ::)
Offline brent j
Re: id of motor
« Reply #4 on: May 25, 2011, 09:03:28 pm »
The list I have says MX400
Offline motomaniac
Re: id of motor
« Reply #5 on: May 25, 2011, 09:12:39 pm »
510 is MX400 B . The 250 was 509.
Re: id of motor
« Reply #6 on: May 25, 2011, 10:05:05 pm »
 ;D Dyslexia hey, welcome to my world :D
Offline TeeBone
Re: id of motor
« Reply #7 on: May 25, 2011, 10:20:01 pm »
Mmmmm, MX400. Sounds like a project, Chris!
Re: id of motor
« Reply #8 on: May 25, 2011, 10:41:55 pm »
Hi Spanish id #510-0xx-xxx is 1975 mx400 id# 510-1xx-xxx is 1976  yzc400 . give me a call have heaps of parts  regards Iain
Re: id of motor
« Reply #9 on: May 25, 2011, 11:40:15 pm »
Parts...... Do you have a piston and rings for one std size ?  also after a barrell or sleeve
IT400C
Re: id of motor
« Reply #10 on: May 26, 2011, 12:25:07 am »
It gets even more complex...
510-0***** is 1975 MX400B
510-1***** is 1976 YZ400C
510-2***** is 1976 IT400C
Tony
Re: id of motor
« Reply #11 on: May 26, 2011, 09:09:01 am »
I reckon I'd have a frame for that Chris, let me know if you want me to look.
IT400C
Re: id of motor
« Reply #12 on: May 26, 2011, 09:15:00 am »
The YZ-C (510-1*****) and IT-C (510-2*****) frames are identical, but the MX-B (510-0****) frame is very slightly different.
All geometry etc is the same, but the MX-B only has one muffler mounting point on the rear frame loop, YZ-C and IT-C have two mounting points.
Tony
(not to mention the obvious swingarm difference of course....)   ::)
« Last Edit: May 26, 2011, 09:16:36 am by IT400C »
SPANISH ARMADA
Re: id of motor
« Reply #13 on: May 26, 2011, 12:30:18 pm »
thanks to all that replied to help id engine yes its first number is a 2 thanks chris
IT400C
Re: id of motor
« Reply #14 on: May 26, 2011, 12:46:01 pm »
Then it's an IT400C motor - same as YZ-C but wide ratio gearbox and lighting coil.
