Author Topic: DT/RT Trajics  (Read 12866 times)
Re: DT/RT Trajics
« Reply #30 on: May 23, 2011, 10:19:57 pm »
Not exactly vmx but it is a dt1
twin leader front and looks like a disk on the rear
« Last Edit: May 23, 2011, 10:24:39 pm by iainyz »
Re: DT/RT Trajics
« Reply #31 on: May 23, 2011, 10:23:29 pm »
A bit better
Firko , it even uses a dt1 frame this I can make . ;D
Re: DT/RT Trajics
« Reply #32 on: May 23, 2011, 10:36:19 pm »
Iain, I know this isn't exactly a DT1/RT1 but it's a close cousin. It's a stock framed MX360 Yamaha modified for dirt track. It gives a pretty good idea what can be done to a DT1 or similar on a budget without having to outlay for a proper dirt tracker frame. The steering rake has been brought in to 25 degrees (or so), Honda CBX wheels (they're really light), and a bit of fibreglass bodywork. We're planning to build a TM250 using a similar engineering philosophy. A DT1 would be just as easy.
Re: DT/RT Trajics
« Reply #33 on: May 23, 2011, 10:38:42 pm »
looks smaller than a DT1
mx250
Re: DT/RT Trajics
« Reply #34 on: May 23, 2011, 11:48:16 pm »
What under the fairing? I see a standard Yammy 7inch front brake, a late '70's RD250/400 tank,. one carby, and it looks like a high pipe on the right. Maybe an AT/CT1 rear hub.
Re: DT/RT Trajics
« Reply #35 on: May 24, 2011, 06:50:27 pm »
Mx250 Im told it is a dt 250 motor in there if you look at the top rear eng mount it looks like a dt with the rib up it ,not sure if its reed or not .
Re: DT/RT Trajics
« Reply #36 on: May 28, 2011, 11:39:30 am »
« Last Edit: May 28, 2011, 11:43:42 am by iainyz »
mx250
Re: DT/RT Trajics
« Reply #37 on: May 28, 2011, 11:57:13 am »
They do mean short    "http://www.youtube.com/v/tq4yzaPM1mg?version=3
It wouldn't be too hard to be lapped  :o ;D
