Author Topic: YZ250f  (Read 4999 times)
Offline walshy
YZ250f
« on: April 08, 2011, 09:08:28 am »
Can anyone help me out with a nut for my front axel. 79 yz250
Offline Viper666
    • Ballarat Rovers MCC
Re: YZ250f
« Reply #1 on: April 08, 2011, 11:15:51 am »
It is nothing special. A standard metric thread. Just take it to a Nuts & Bolts joint they have one.
Unless it for authenticity.
Offline walshy
Re: YZ250f
« Reply #2 on: April 08, 2011, 12:18:47 pm »
Cheers for that although it appears that i don't have f forks.Apparently the 250f fork base was threaded for the axel hence why I can't get a nut for it.
My forks have 4 bolts on the axel clamp side and are 38mm. Any Ideas?
P.S. Want a NOS axel for a 250f?
Offline motomaniac
Re: YZ250f
« Reply #3 on: April 16, 2011, 10:00:36 pm »
sounds like you have later model forks, possibly 83 125. F forks should have one pinch bolt .
Re: YZ250f
« Reply #4 on: April 18, 2011, 10:30:06 am »
I thought the 250F had two M8 pinch bolts?
Could also be YZ125H/J, or various ITs.
Offline Viper666
Re: YZ250f
« Reply #5 on: April 20, 2011, 10:04:35 am »
YZ250F has only 1 pinch bolt. G has 2, H has 2 but are 43mm.
They sound like IT175J/K (82,83), IT200L (84) or IT250/465H/J (81,82) forks. Almost bet the farm.
As Nathan said they may be off a YZ125H/J but look at the bottom tripple clamp it has a recess for the radiaror water in/outlet.
Viper666
« Last Edit: April 20, 2011, 10:22:32 am by Viper666 »
Re: YZ250f
« Reply #6 on: April 20, 2011, 10:57:21 am »
IT200s were 43mm, FWIW.
Offline motomaniac
Re: YZ250f
« Reply #7 on: April 20, 2011, 11:06:24 am »
Viper666
YZ125 K is also 38mm with no triple clamp water outlet.Anyway he might have the original 38mm triple and later forks.
Re: YZ250f
« Reply #8 on: April 20, 2011, 12:47:36 pm »
He has the right triples, it's just the forks that are wrong. Are all the possible forks mentioned in the same ballpark in terms of length? I know some of the later ones don't stick up through the top clamp like the original 250f forks do
Offline motomaniac
Re: YZ250f
« Reply #9 on: April 20, 2011, 01:35:49 pm »
125 K forks dont stick up above the clamps but have 12" travel so about 1.3" longer than stock.
38mm E forks have shorter stauchions than the F so they dont stick up so much , abit less travel also but that can easy be changed to match F specs.
Re: YZ250f
« Reply #10 on: April 20, 2011, 01:38:43 pm »
Yeah, they're all the super long type - maybe not the YZ125K - and there's probably some variation between them.
The IT175J/K forks have about 275mm of travel. Pretty sure the YZs had the full 300mm. Dunno about the IT250/465s.
Eh, MM made most of this redundant while I was typing.
