Author Topic: new guy from Holland  (Read 4807 times)
Offline Eldert
« on: January 29, 2011, 02:49:51 am »
hi Guys
my name is Eldert and i live in the Netherlands .
i have a couple Ducati 450 RT Desmos . i converted one into a play bike
i did a little write up on another forum . here is the link
http://www.motoscrubs.com/forum/viewtopic.php?f=3&t=20&start=20
my other 450 RT i like to make a vintage motocrosser .
Eldert
Re: new guy from Holland
« Reply #1 on: January 29, 2011, 06:56:36 am »
"t is a 450 bored and stroked ( 90 X 78 )taken out to 496 cc .i put a springer head on with reangled oversize valves
74 degrees combined valve angle and 44 mm and 38 mm valves
i had new inputshafts made up that wont break and put on straight cut primary gears with a differend ratio
to speed up the gearbox so there is less load on the gears
i made the rear swing arm 2 inches longer and i put Scrambler bottom sliders on the front fork and laced
a Grimeca 180 mm 4 shoe brake to the 21 inch rim
put in a alternator instead of the flywheel magneto ignition and converted to 12 volts
electronic ignition is Boyer and no battery is fitted but a Boyer Powerbox to rectify and store some energie"
Wow! Nice and dedicated work.
It think Firko just got a new Best Friend and his deck chairs just got rearranged ;D.
Offline gordon67
« Reply #2 on: January 30, 2011, 06:15:39 am »
Hi Eldert
Welcome to the forum.....a fine machine and project you have there,...also i am very interested if your next project =the motorcrosser  is or will be engineered to run on methanol or pump fuel...its interesting to see which way you go with that particular bike  good luck
« Reply #3 on: January 30, 2011, 10:26:30 am »
A recent change in direction might just see a Triumph 500 engine replace the 250 Ducati in the Hindall...a real rearrangement of the deck chairs ;D. It's not a definite as it all depends on what condition I find the Trumpy in once I pull it down.
Welcome Eldert, your Ducati projects are pretty interesting...keep us up to date on your progress.
ps...I bet the exhaust on your RT450 sounds pretty distinctive ;D.
« Last Edit: January 30, 2011, 11:12:43 am by firko »
Offline pancho
« Reply #4 on: January 30, 2011, 10:59:29 am »
Welcome Eldert, I am in awe of your engineering ability and prowess with the cylinder head mods. cheers pancho
Offline Mike52
  • 81 KTM 125 LC
« Reply #5 on: January 30, 2011, 01:43:50 pm »
Hi.
Really like a guy willing to have a go and thinks outside the box. :)
Welcome.
Offline Eldert
« Reply #6 on: January 30, 2011, 08:40:12 pm »
in 1971 the ISDT was held on the Isle of Man . the Italian team rode on 350 and 450 Ducati RTs that year
the exhaust that i fitted on my bike  was fitted to the teams bikes to
nice Hindall . i have a picture of that frame on my hard drive . it was offered to us before it went to E Bay
Eldert
SAABCOMBI
« Reply #7 on: January 30, 2011, 10:12:50 pm »
Mark, leave it as it is, very nice and neat 250.
