Author Topic: Wiseco pistons  (Read 7881 times)
Wiseco pistons
« on: January 13, 2011, 09:23:52 pm »
Firstly - are there any Yamaha gurus out there that tell me the Wiseco piston part numbers corresponding to what YZ360B pistons - is that confusing???
Secondly - is it pronounced Wise-co or Wi-seco????
Ahhhhh!
Offline GD66
Re: Wiseco pistons
« Reply #1 on: January 13, 2011, 09:25:22 pm »
Wise-co.
Re: Wiseco pistons
« Reply #2 on: January 13, 2011, 10:21:16 pm »
Seiz-co. ;) ;D
Re: Wiseco pistons
« Reply #3 on: January 13, 2011, 10:25:08 pm »
You should be able to get a Wossner or ProX over your way from BB Importers, Norm's the guy there that nows but you will have to go through a bike shop.
Offline Big John
Re: Wiseco pistons
« Reply #4 on: January 13, 2011, 10:42:47 pm »
I got warned off Wiseco pistons when I rebuilt a yz/wr. I was told to get a Pro-x piston as they were better quality and cheeper aswell.
Offline GD66
Re: Wiseco pistons
« Reply #5 on: January 13, 2011, 11:03:33 pm »
Better tell that to all the LC250 Yamaha roadracers that received the same advice, then suffered cracks across their piston crowns from one small-end eye to the other... :o
Offline oldyzman
  • 250 two stroke!
Re: Wiseco pistons
« Reply #6 on: January 13, 2011, 11:21:54 pm »
try get a wossner from UK... just ordered on for my cr250 it was $190 incl little end bearing and an oversize piston kit...
Cheers Brett
Re: Wiseco pistons
« Reply #7 on: January 13, 2011, 11:42:26 pm »
Davy - you're a wanker!!!!  ;D
thanks for the advice gents - shall go looking further now.
Rossco
Re: Wiseco pistons
« Reply #8 on: January 13, 2011, 11:53:10 pm »
Ross, nothing wrong with the wiseco's and i have been getting full kitsw out of the US for $60, so you can afford to change them like you undies.  you can use the MX 360 piston or the RT1 and cut your own intake arc if you prefer it that way
Re: Wiseco pistons
« Reply #9 on: January 13, 2011, 11:53:40 pm »
WHat oversize do you need ?
Re: Wiseco pistons
« Reply #10 on: January 14, 2011, 12:37:36 am »
Freaky - you have forgotten me already  :'( - I am chasing std 360B YZ piston - you were going to get back to me whether you had one for sale?  But I see lots of Wiseco pistons in the US but don't know which Wiseco numbers correlated to what YZ pistons.  Have started searching for Wossner and Pro X also.
Re: Wiseco pistons
« Reply #11 on: January 14, 2011, 02:39:03 am »
1000's of people use Wiseco, i dont think they are that bad, Once in a blue moon you might hear of a failure but i bet it wasnt the pistons fault anyway. These days you will get the odd breakage of any component on a competion/racing vehicle, its the nature of racing.
I reckon it is Rick Horvat in USA who gets special pistons made up by Wiseco for older odd models not in Wisecos standard listing.
DR
Re: Wiseco pistons
« Reply #12 on: January 14, 2011, 07:08:51 am »
Wiseco kit #184, #220, #231 all suit DT/RT/MX/YZ360...at least that's what the good book says ;)
184 and 220 are possibly the older dykes single/double ring type kits in the blue boxes. Used wiseco's in most of my bikes for God knows how long and not a single issue to date even with these old kits ;)
Re: Wiseco pistons
« Reply #13 on: January 14, 2011, 02:38:42 pm »
Doc - thanks - have seen 184's but do you know if they match say a xxxxxx-96 model Yamaha one etc?  Also can you mix and match - ie Yamaha rings Wiseco pistons or best keep same same?
Re: Wiseco pistons
« Reply #14 on: January 14, 2011, 07:33:04 pm »
Hi no luck with mix and match first thing I checked. I use the rick's pistons never had a problem with ricks or wiseco
