Author Topic: Wiseco pistons  (Read 7881 times)
Re: Wiseco pistons
« Reply #15 on: January 19, 2011, 06:26:34 pm »
the standard bore size is cheap as shit ( assume you have a steel sleeve in there.) can do wisco and yamaha, must have forgotten you :O) sorry i get easily distracted.  the CD rings for the Wisco are universal to them so you they are thye same for the suzi kits etc, you just look up and buy the ring if its not in the kit liek a CD 2275 etc the rings are like $10 on ebay,  like DOC and Leith said nothing wrong with wiseco, depends on the user and who does the clearances.
I have Rt1 standard bores unles you absolutely must have a yz curve.  Ic an sell you a window or posibly a Piston port in 96/98 and you can scupt your own intake curve.
Depends how anal you are i guess.....................
Re: Wiseco pistons
« Reply #16 on: January 19, 2011, 07:16:06 pm »
Freaky - love you long time GI.
Mate - I have standard Yamaha rings - also have had both a MX piston and YZ piston in it - so would prefer the YZ piston.  If you have a standard size YZ piston I will buy one from you?????
