Author Topic: Mikuni ID/help needed  (Read 6797 times)
Doc
« on: January 21, 2008, 06:44:58 pm »
Does anyone recognize the carb below or can anyone give some advice?? It's 32mm but...???
I won it today on eBay for about $7.00 hoping it would be okay for the RM125S motor. Looks like a powerjet but I don't know enough about them  :-\ was going to blank it off if it is..snowmobile maybe?? It's from the US..can I use it if I block or remove the powerjet bits??
Offline DJRacing
  • YZ125X
Re: Mikuni ID/help needed
« Reply #1 on: January 21, 2008, 06:49:10 pm »
Doc is there a part number by the choke?
Doc
« Reply #2 on: January 21, 2008, 06:57:02 pm »
Deej, I haven't actually got the carb in my mitts but the guy says the model number is 500 61 B 4V  :-\
I also picked up a super nice priced CR125M Keihin..was hoping to fit this sucker to the TS/TM125. 28mm?? I've never had much to do with these carbs..do they work ??? CR's seem to like em'  ;)
« Last Edit: January 21, 2008, 06:59:43 pm by Doc »
Offline DJRacing
  • YZ125X
« Reply #3 on: January 21, 2008, 07:19:54 pm »
Keihin carbs have me stumped, I dont think I have one anywhere. I dont recognize the part number but I'm sure someone here will.
Doc
« Reply #4 on: January 21, 2008, 07:25:55 pm »
this is the Keihin
 paid  $15.00 for this one but I fuggered the jetting would be somewhere 'near' the ballpark  :P
Offline brent j
« Reply #5 on: January 21, 2008, 07:45:48 pm »
The only possible help I can give Doc is-
500, the first bit of the part No is DT400B
maybe, maybe not
Brent
Doc
« Reply #6 on: January 21, 2008, 08:04:32 pm »
Thanks Brent, until I get the carb and look closer I'll be none the wiser I'd say. From what I've read Mikuni introduced the powerjets onto snowmobiles in the 70's. The carbs does look 70's to me with that high top. Least it was cheap  ;)
« Reply #7 on: January 21, 2008, 08:28:10 pm »
Don't you dare block that power jet off  >:(
Looks perfect for a 125,the power jet allows a leaner needle to be run so you can have blistering top end without going blubbery on the needle.A small tweek can have that powerjet adjustable and working beautifully.The powerjet just sucks fuel dirctly from the float bowl into the airstream when the velocity is high enough.
Nothing to fear and plenty to gain.Just check the needle/seat size sleds usually have BIG sizes in there
 ;D
Doc
« Reply #8 on: January 21, 2008, 08:38:16 pm »
errr..I didn't think you were allowed to run powerjets Loz..if so for sure I'll retain it but I need to consult the 'Book' first..I'll do that right now  ;)
« Reply #9 on: January 21, 2008, 10:25:05 pm »
Flatslide no, powerjet well...... (whistling while looking up)
Doc
« Reply #10 on: January 24, 2008, 02:49:41 pm »
Could I get clarification from someone in the know as to whether I can actually run a powerjet carb since it is infact era? The bike will be pre'78. I can't find a reference to them in 'THE BOOK' and it could be just what the S motor is begging for :)
« Reply #11 on: January 24, 2008, 07:40:49 pm »
Pre 75 says "No Flatslides" that's about the only reference to carbs in the GCR's individual meeting supp regs might be different.A great many are probably bliisfully unaware of the neddies lurking inside that PJ.
Doc
« Reply #12 on: January 25, 2008, 08:10:27 am »
Loz..I was tuned into these carbs a little with a project a friend and I built quite a few years back. T'was on an RZ500 minisprint. Fitted the powerjets (amongst other things) and he got himself a state title ;D just like playing with a YZ125 only times 4 with everything  :) the pipes we made actually worked..I'll find a pic  ;)
« Last Edit: January 25, 2008, 08:14:42 am by Doc »
« Reply #13 on: January 25, 2008, 10:48:58 pm »
RZ 500 already has PJ carbs but incy wincy 28mm jobbies.Lucky you were blissfully unaware of the problems with the RZ 500(and the RG500) main one being the rear bank being up to 8degrees out.
« Reply #14 on: January 25, 2008, 10:53:54 pm »
so power jets are one of the ad on accessories you are in favour of Lozza ;D
