Author Topic: Tm air box  (Read 7162 times)
Tm air box
« on: November 14, 2010, 03:19:48 pm »
Yes this is a Tm 250 air box , and it cost me jack shit ( $3-00 to be precise) at our local tip shop ;D .    Beats paying outragous prices and postage out of USA of which they are fetching currently.
Base   OD    =  195 mm    same as  TM
Top    OD    =   170 mm
depth         =   110 mm
« Last Edit: November 14, 2010, 04:19:51 pm by oldfart »
Re: Tm air box
« Reply #1 on: November 14, 2010, 04:42:45 pm »
Next you will need a Suzuki  Pe 250 / 400  1980/81  cage and base ....next the hard part a Tm air box boot
Re: Tm air box
« Reply #2 on: November 14, 2010, 04:56:27 pm »
Next step remove handle, and mark centre of pot ( bottom side of course ) then scribe a mark from left to right .
From your centre line dot punch 60mm either side being 120mm apart .... drill these out with a 18mm drill bit
 Next - If you don't have a lathe, get a compass and set it @ 39mm then draw a circle being 78mm, this will need to be cut out fairly accurately to line up with your 18mm holes  ;)
If you have a lathe, clamp the pot internaly and centre it up on centre point on pot ( I used shims )
Re: Tm air box
« Reply #3 on: November 14, 2010, 05:03:41 pm »
As you can see it's a nice fit and looks like it belongs there. All that is needed to finish it off is a few brackets tig welded to pot aligning up with frame brackets.   note... I will be using rubber tap washers ...yellow of course to allow for vibrations between frame bracket and pot lugs.
« Last Edit: November 14, 2010, 05:07:00 pm by oldfart »
Offline frostype400
Re: Tm air box
« Reply #4 on: November 14, 2010, 05:58:37 pm »
That is pretty cool Stewart why didn't you just take one from the kitchen rather than the tip than you could have shown your wife where the missing cooking pot went. ;)
1971 tm400 and PE's
monaro308
Re: Tm air box
« Reply #5 on: November 14, 2010, 06:47:03 pm »
Aussie ingenuity at its best!....love it
Re: Tm air box
« Reply #6 on: November 14, 2010, 06:47:54 pm »
I'd say $3 is a lot better than the grief he would have gotten for your suggestion frosty ;)
TM BILL
Re: Tm air box
« Reply #7 on: November 14, 2010, 06:54:52 pm »
Stu your a clever bugger  ;D well done mate  :)
Offline brent j
Re: Tm air box
« Reply #8 on: November 14, 2010, 07:24:02 pm »
I think Kiwi ingenuity may closer to the mark ;)
Re: Tm air box
« Reply #9 on: November 14, 2010, 07:36:00 pm »
Are you masquerading as Ji now.....dont sent me any pm's!!! ;D
Re: Tm air box
« Reply #10 on: November 14, 2010, 07:51:09 pm »
Are you putting some sort of lid/cover on it?
Offline cyclegod
  • Sunny PERTH W.A
    • cyclegod on "youtube"
Re: Tm air box
« Reply #11 on: November 14, 2010, 07:55:19 pm »
Now "going to pot" has a whole new definition  :D ;D
Ban BLACK rims NOW
Re: Tm air box
« Reply #12 on: November 14, 2010, 08:30:56 pm »
Thanks gentlemen and John  ;D
Leith , from what I have been told TM  air boxs on these old girls where a bit restrictive. With this set up it is about 15mm off the rear guard and is pretty much protected from rear wheel debri..... it's suck it see, as they say.
Ali pots have been linked with Oldtimers, they are few and far between these days   Frosty
Re: Tm air box
« Reply #13 on: November 14, 2010, 09:12:03 pm »
I guess while your circulating your lunch is getting cooked at the same time. ;D
Offline brent j
Re: Tm air box
« Reply #14 on: November 14, 2010, 09:32:36 pm »
He's got a cover there Leith and it's anodised a pretty red! :o ;D
The air box looks like it meant to be there Stu. I don't know about the washers for the air box but the rubbers for the oil tank are still available, they used them on outboards up until 3-4 years ago. Same part # too
