Author Topic: cr250 what year?  (Read 12702 times)
Offline frostype400
cr250 what year?
« on: October 29, 2010, 08:12:38 pm »
I guessed 84 on the way the disc is at the front but I am not an expert on these or much else. ;)
1971 tm400 and PE's
Offline E74
Re: cr250 what year?
« Reply #1 on: October 29, 2010, 08:13:46 pm »
'85
Offline frostype400
« Reply #2 on: October 29, 2010, 08:17:54 pm »
ok so do the stickers say that but the 85 doesnt have the same disc can I tell from #'s
1971 tm400 and PE's
« Reply #3 on: October 29, 2010, 08:33:09 pm »
Look at the engine covers
Offline frostype400
« Reply #4 on: October 29, 2010, 08:41:46 pm »
Oh ok so definetly 85 then would it be worth $50 needs a seat and I don't know what the motor is like.
1971 tm400 and PE's
« Reply #5 on: October 29, 2010, 08:48:39 pm »
Whats the engine and frame number? that will 100% tell you what it is.
090
« Reply #6 on: October 29, 2010, 08:58:16 pm »
Its an '84.
You buying or selling? 'cause I'm buying if you only want $50!
Offline frostype400
« Reply #7 on: October 29, 2010, 09:02:50 pm »
sweet no I cant really sell my mate is a scrap metal bloke this was heading for the junk yard so I said don't do that I will do that up would be a little bit rude to sell it for more than I paid and I don't want to sell it for $50. ;)
1971 tm400 and PE's
090
« Reply #8 on: October 29, 2010, 09:04:19 pm »
No problemo  :)
http://100megsfree4.com/honda/h0200/cr250r.htm
Check the shrouds. That is the give away as they are that shape for the one year only.
Offline frostype400
« Reply #9 on: October 29, 2010, 09:10:40 pm »
Cool if I do bring myself to sell I will let you know. ;)
probably do it up a racer get on the track. :)
1971 tm400 and PE's
Offline E74
« Reply #10 on: October 29, 2010, 09:51:28 pm »
OK, well it may well be an '84 but is has an 85 motor in it because it has the ATAC inspription on the barrel and not on the power valve cover,  it also has '85 swingarm, defenitely an '84 tank on it however.
also has blue shock spring which is right for 85-87, 84 models had red shock springs.
« Last Edit: October 29, 2010, 09:53:34 pm by E74 »
090
« Reply #11 on: October 29, 2010, 10:07:16 pm »
Yes! I looked at the shrouds and front disc as they are '84. But you are right too. Its the 84/85 model  ::)
Makes more sense that its an '85 with some '84 parts on it.
Offline frostype400
« Reply #12 on: October 30, 2010, 09:51:09 am »
so it is a bit of a bastard thing what should I do with it is it pre 85 eligable or not.
I will put up the frame and motor numbers. :)
1971 tm400 and PE's
Offline E74
« Reply #13 on: October 30, 2010, 11:02:15 am »
1984 •The serial number began JH2ME0304EC600001.
1985•The serial number began JH2ME0309FC700001
« Reply #14 on: October 30, 2010, 12:09:23 pm »
did you find this info on the web E74?
