Author Topic: cr250 what year?  (Read 12936 times)
Offline caps 999
Re: cr250 what year?
« Reply #15 on: October 30, 2010, 06:38:45 pm »
Go by the10th digit of theframe number
1980=A
1981=b
82=c
83=d
84=e
85=f
86=g
MUGEN power
Offline frostype400
« Reply #16 on: October 30, 2010, 06:41:43 pm »
thanks will check it tommorow. ;)
1971 tm400 and PE's
Offline frostype400
« Reply #17 on: October 30, 2010, 07:05:52 pm »
I checked the frame F so it is 85 with some 84 gear I would swap the tank for 85 and 84 front end for 85. ;)
1971 tm400 and PE's
Offline caps 999
« Reply #18 on: October 30, 2010, 07:19:51 pm »
I'll buy the 84 front if you wanna move it on I stiffed one of the legs on mine
MUGEN power
Offline frostype400
« Reply #19 on: October 30, 2010, 07:21:27 pm »
So did I buy a lemon. ???
yeah but I would need a replacement caps it had a few small pits between the trees unless I sell the whole bike or swap for a suzuki.
1971 tm400 and PE's
Offline caps 999
« Reply #20 on: October 30, 2010, 07:24:17 pm »
Chrome condition isn't an issue I only need base parts and for $50 you can't go wrong I'll give you 100 for the forks
MUGEN power
Offline frostype400
« Reply #21 on: October 30, 2010, 07:27:37 pm »
I will have a look at it tommorow it owes me nothing there is a heap of goo on the water pump area did these rot like the 125's did?
1971 tm400 and PE's
« Reply #22 on: October 30, 2010, 08:12:01 pm »
A CR250 MOTOCROSS BIKE FOR $50 YOU CANT COMPLAIN!!!! Its not a XL100 or something so basically i reckon you got a very good bargain.
You can easily make 10X that if you part it out on ebay, look at all the guys that do it, they arent silly.
And there you go, capps is offering $100 for the forks, you could get $30 for mag cover, $50 for the clutch cover, $75 for the trans etc etc, it all adds up quickly and before you know it you got several hundred in your pocket to throw towards your PE's or what ever. ! I just bought a PE transmission set in Canada for $50 i think, plus a kick starter shaft for about $25 a CDI for $50 plus more bits and before i knew it i had bought over $200 US in engine parts and few other things. I maybe could have bought a complete motor here for $300 but i didnt really care because i wanted good condition low hour parts and overseas is where you find them.
So if you want to make make money parting it out is the way to go, otherwise if you wanna do it up, since you already paid only $50 for it which is just lunch money these days, you almost got a free bike and you have got a headstart already and can aford to spend $1000 on it. Its not like you have paid $600 for it already and still gonna need to spend another $1000 on it.
« Last Edit: October 30, 2010, 08:15:00 pm by LWC82PE »
Offline frostype400
« Reply #23 on: October 30, 2010, 08:24:35 pm »
I am only joking about the $50 for that much I could throw petrol on it and set it on fire but no way I will do that I would have paid more for it our factory is supposed to be done now but I might drive past tommorow and see then no worries how many bikes I get I will just buy a seat and decent pipe and it is complete. :)
It was going to get scrapped by my mate so it is saved. :)
1971 tm400 and PE's
Offline E74
« Reply #24 on: October 30, 2010, 09:32:49 pm »
1984 •The serial number began JH2ME0304EC600001.
1985•The serial number began JH2ME0309FC700001
did you find this info on the web E74?
http://www.motorera.com/honda/h0250/cr250r/cr250r.htm
Offline frostype400
« Reply #25 on: November 09, 2010, 09:51:23 pm »
I am actually a bit suprised by this bike it isn't as bad as it looks I mean it was obviously owned by some one who was good at putting go fast stickers on and not much else. ;)
I am a bit worried though did these rot in the water pump area there are screws missing in the crank cases and high temp red has been used on the water cover maybe as a gasket?
I need a seat and I will buy a new or good second hand crank case/water pump cover.
1971 tm400 and PE's
« Reply #26 on: November 10, 2010, 07:51:41 pm »
Sadly Michael they did and very bad corrosion too.
Offline frostype400
« Reply #27 on: November 10, 2010, 07:53:46 pm »
I will check it out on the weekend hopefully it isn't to bad it hasn't got any water in it maybe it might be ok who knows.
The guys at the local wreckers told me not to get a cr of that era for that reason if it is buggered what is the fix a bit of welding?
1971 tm400 and PE's
Offline frostype400
« Reply #28 on: November 11, 2010, 05:40:17 pm »
checked the water pump area it is a bit :-\ but not majorly bad I will try and get another right hand side complete casing.
1971 tm400 and PE's
« Reply #29 on: November 11, 2010, 06:01:00 pm »
gtting a good case will be hard as they all have that problem.
if it is repairable it can be welded or devcon can be used. if devcon has been used on it before then welding is not an option.
