Author Topic: YZ125C + MX125C project bikes plus extras.  (Read 11677 times)
« on: October 13, 2010, 10:45:28 pm »
See post 18/7/11 (fourth post on page 2) for significant revision!
All there, needing normal rebuild stuff.
Matching numbers, with original steel handlebars (straight!).
$600 complete, or $400 without fuel tank.
Pics in the next few days.
In Yass, southern NSW (near Canberra) Can deliver to Sydney/Wollongong/Canberra in the near future, if that helps?
Nathan
04000 23847.
« Last Edit: July 18, 2011, 10:27:43 pm by Nathan S »
Offline SimonC
Re: YZ125C project bike.
« Reply #1 on: October 14, 2010, 12:01:42 pm »
Hi Nathan
I am needing a carby and rear guard for my 125c - do you have anything spare?
Simon
« Reply #2 on: October 14, 2010, 12:09:57 pm »
I've got a spare 30mm Mikuni, but I'm not sure if I've got a spare YZ125C one - will have to check.
No decent 125C rear guards - do have a rough 125X guard if you are prepared to paint it?
Offline mick25
  • Hunter valley NSW
« Reply #3 on: October 15, 2010, 08:51:08 pm »
I sent you a pm nathan no reply, will try here just seeing if you still have the tank 4 sale, 4 the 125 c
Thanks mick
Offline steveo247
« Reply #4 on: October 16, 2010, 01:06:19 pm »
waiting for pics  :)
TM BILL
« Reply #5 on: October 16, 2010, 02:15:23 pm »
Nathan check your Pms  ;D
« Reply #6 on: October 17, 2010, 05:07:09 pm »
Some bits a bit rougher than I remembered, so price/spec is negotiable.
Your choice of fuel tanks. I put the bog in the yellow one, and its about the same as the white one underneath. Finger points to the heaviest bog applications.
Shock seems to have good chrome, but is obviously leaking. I have other shocks if you want to take your chances with them instead.
Airbox seems intact (they often break in two).
Cylinder is on a fairly small bore - 2nd or 3rd OS, IIRC (Wiseco do up to +2.00mm).
Needs a big end, or I can supply a crank with a decent used rod in it.
Forks are the what rougher than I remembered. There's three in the pic: two legs with decent chrome on the seal area, and the third to make a pair (the good ones are both from the same side). Alternatively, if you're happy to rechrome, then there's several pairs that need rechroming - will sell with them for less money if that suits.
Seat foam isn't as bad as it looks. The old upholstery trick of using a thin layer of foam should easily hide the imperfections. New foams are available too.
Photos of other spare bits - not included, but just in case you're worried "What if the XX is missing?":
« Last Edit: October 17, 2010, 05:09:49 pm by Nathan S »
Offline SimonC
« Reply #7 on: October 18, 2010, 12:11:18 pm »
Thanks Nathan
PM sent.  I woyuld be keen on the 30mm carb and the mudguard.
Simon
« Reply #8 on: March 31, 2011, 03:06:27 pm »
Hey NAthan what of this YZ  if any you got left ?
Offline SimonC
« Reply #9 on: April 01, 2011, 12:25:01 pm »
I am still cahsing some bits as well if there is anything left.
Simon
« Reply #10 on: April 01, 2011, 12:47:08 pm »
All still here.
Call me (this includes you, Mr IT400C).
N.  :)
Offline mickj
« Reply #11 on: April 16, 2011, 09:33:05 pm »
Nathan
 Im after a airbox for my 125X or & as near to a complete 125c albeit in pieces as I can get
 Pm me thanks
« Reply #12 on: April 18, 2011, 12:01:48 am »
Nath you were getting back to me about the seat and the motors, made any headway yet ?
« Reply #13 on: April 21, 2011, 12:38:35 pm »
nathan are you ever going to get back to me ????
« Reply #14 on: April 21, 2011, 03:18:35 pm »
You in a hurry?
If so, then the answer is "No"....
The boxes of stuff are currently buried very deeply and not easily accessed.
If you start waving cash, then I'll drag 'em out and sort through them... until then, you'll have to wait until I sort through my backlog of crap.
