Marketplace
For Sale
YZ125C + MX125C project bikes plus extras.
3
All
Topic: YZ125C + MX125C project bikes plus extras. (Read 12275 times)
Nathan S
Superstar
HEAVEN #818
October 13, 2010, 10:45:28 pm »
See post 18/7/11 (fourth post on page 2) for significant revision!
All there, needing normal rebuild stuff.
Matching numbers, with original steel handlebars (straight!).
$600 complete, or $400 without fuel tank.
Pics in the next few days.
In Yass, southern NSW (near Canberra) Can deliver to Sydney/Wollongong/Canberra in the near future, if that helps?
Nathan
04000 23847.
Last Edit: July 18, 2011, 10:27:43 pm by Nathan S
SimonC
B-Grade
Re: YZ125C project bike.
October 14, 2010, 12:01:42 pm »
Hi Nathan
I am needing a carby and rear guard for my 125c - do you have anything spare?
Simon
Nathan S
Superstar
HEAVEN #818
October 14, 2010, 12:09:57 pm »
I've got a spare 30mm Mikuni, but I'm not sure if I've got a spare YZ125C one - will have to check.
No decent 125C rear guards - do have a rough 125X guard if you are prepared to paint it?
mick25
Hunter valley NSW
October 15, 2010, 08:51:08 pm »
I sent you a pm nathan no reply, will try here just seeing if you still have the tank 4 sale, 4 the 125 c
Thanks mick
steveo247
A-Grade
Reply #4 on:
October 16, 2010, 01:06:19 pm »
waiting for pics
TM BILL
Reply #5 on:
October 16, 2010, 02:15:23 pm »
Nathan check your Pms
Nathan S
Superstar
HEAVEN #818
Reply #6 on:
October 17, 2010, 05:07:09 pm »
Some bits a bit rougher than I remembered, so price/spec is negotiable.
Your choice of fuel tanks. I put the bog in the yellow one, and its about the same as the white one underneath. Finger points to the heaviest bog applications.
Shock seems to have good chrome, but is obviously leaking. I have other shocks if you want to take your chances with them instead.
Airbox seems intact (they often break in two).
Cylinder is on a fairly small bore - 2nd or 3rd OS, IIRC (Wiseco do up to +2.00mm).
Needs a big end, or I can supply a crank with a decent used rod in it.
Forks are the what rougher than I remembered. There's three in the pic: two legs with decent chrome on the seal area, and the third to make a pair (the good ones are both from the same side). Alternatively, if you're happy to rechrome, then there's several pairs that need rechroming - will sell with them for less money if that suits.
Seat foam isn't as bad as it looks. The old upholstery trick of using a thin layer of foam should easily hide the imperfections. New foams are available too.
Photos of other spare bits - not included, but just in case you're worried "What if the XX is missing?":
Last Edit: October 17, 2010, 05:09:49 pm by Nathan S
SimonC
B-Grade
Reply #7 on:
October 18, 2010, 12:11:18 pm »
Thanks Nathan
PM sent. I woyuld be keen on the 30mm carb and the mudguard.
Simon
Freakshow
Superstar
Adelaide, SA - looking for a "YZA" tank
Reply #8 on:
March 31, 2011, 03:06:27 pm »
Hey NAthan what of this YZ if any you got left ?
74 Yamaha flattracker's
70 Jawa 2 valve speedway's
For sale - PRE 75 Yamaha MX stuff, frame, motors and parts also some YAM DT1,2,A and Suzi TS bikes and stuff
SimonC
B-Grade
Reply #9 on:
April 01, 2011, 12:25:01 pm »
I am still cahsing some bits as well if there is anything left.
Simon
Nathan S
Superstar
HEAVEN #818
Reply #10 on:
April 01, 2011, 12:47:08 pm »
All still here.
Call me (this includes you, Mr IT400C).
N.
mickj
Novice
Reply #11 on:
April 16, 2011, 09:33:05 pm »
Nathan
Im after a airbox for my 125X or & as near to a complete 125c albeit in pieces as I can get
Pm me thanks
Freakshow
Superstar
Reply #12 on:
April 18, 2011, 12:01:48 am »
Nath you were getting back to me about the seat and the motors, made any headway yet ?
Freakshow
Superstar
Reply #13 on:
April 21, 2011, 12:38:35 pm »
nathan are you ever going to get back to me
Nathan S
Superstar
HEAVEN #818
Reply #14 on:
April 21, 2011, 03:18:35 pm »
You in a hurry?
If so, then the answer is "No"....
The boxes of stuff are currently buried very deeply and not easily accessed.
If you start waving cash, then I'll drag 'em out and sort through them... until then, you'll have to wait until I sort through my backlog of crap.
3
All
Marketplace
For Sale
